Etude des défauts étendus induits par irradiation dans UO2 par microscopie électronique en transmission - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2016
Study of extended defects created under irradiation in UO2 using the transmission electron microscopy
During in-reactor irradiation, several phenomena take place in the uranium dioxide fuel: fission gas bubbles and extended defects (dislocation loops and lines) generation, doping by fission products, etc. Fission gas release is an important nuclear safety issue and represent, among others, a limiting factor for the fuel lifetime in reactors. It has been shown experimentally that the extended defects are preferential growth sites for fission gas bubbles. Hence, the study of extended defects created under irradiation is a significant step to better understand the fuel behavior. The aims of this study are to determine the extended defect characteristics (Burgers vectors, habit planes, interstitial or vacancy nature), their evolution mechanisms and the effect of the different irradiation parameters, such as fluence, temperature and exogenous atoms, on the evolution kinetics. To do that, separated-effects studies have been performed using ion irradiations/implantations (JANNuS facilities in Orsay and in Saclay) followed by in situ TEM characterizations (CEMES, JANNuS Orsay), XRD and Raman spectroscopy measurements. Finally, the characterization of fuel irradiated in reactor performed at JRC-ITU, revealed that extended defects are very much closed to those induced by ion irradiations, in terms of density and characteristics.
Lors de son irradiation en réacteur, le dioxyde d'uranium subit d'importantes modifications physico-chimiques (génération de bulles de gaz de fission, création de dislocations...). Le relâchement des gaz de fission est un critère important du point de vue de la sureté nucléaire, limitant le temps de vie du combustible en réacteur. Or, la croissance préférentielle des bulles localisées sur les défauts étendus a été mise en évidence expérimentalement. Le but de ce travail est donc d'étudier les dislocations induites par irradiation, afin d'améliorer la compréhension du comportement du combustible. Les objectifs sont de déterminer les caractéristiques des défauts étendus (vecteur de Burgers, plan d'habitat, nature interstitielle ou lacunaire), leurs mécanismes d'évolution (nucléation, grossissement), ainsi que l'influence de différents paramètres d'irradiation, tels que la fluence, la température et la présence d'atomes exogènes sur leur cinétique d'évolution. Pour ce faire, des études à effets séparés basées sur la réalisation d'irradiations aux ions (plateformes JANNuS d'Orsay et de Saclay) et de caractérisations in situ à différentes échelles comme des observations au Microscope Electronique en Transmission (CEMES, JANNuS Orsay), des mesures de Diffraction des Rayons X et de spectroscopie Raman, ont été mises en place. Enfin, la caractérisation du combustible irradié en réacteur réalisée à JRC-ITU, a révélé des défauts étendus très semblables à ceux induits par des irradiations aux ions, en termes de densité et de caractéristiques.
2016TOU30183b.pdf (14.58 Mo) Télécharger le fichier
tel-01620533 , version 1 (20-10-2017)
  • HAL Id : tel-01620533 , version 1
Claire Onofri. Etude des défauts étendus induits par irradiation dans UO2 par microscopie électronique en transmission. Physique Nucléaire Expérimentale [nucl-ex]. Université Paul Sabatier - Toulouse III, 2016. Français. ⟨NNT : 2016TOU30183⟩. ⟨tel-01620533⟩
367 Consultations
424 Téléchargements
