Optimisation de la performance de l’épidémiologie d’intervention en santé animale - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2016
Enhanced emerging animal disease surveillance and investigation capacities
Emerging disease surveillance and investigation aim at the early detection of any health threat in order to perform a comprehensive analysis of the disease situation to help target an appropriate response. Its expansion in the field of animal health is led by major health, economic, and public health drivers. In support of this ongoing development, a standard structure for improved emerging animal disease surveillance and investigation capacities was established. This structure was based on a Business Process Management (BPM) approach.The primary goal of this work was to identify chains of activities (processes) that can support the most successful implementation of emerging animal disease surveillance and investigation, while buidling on the achievements made in the public health area. These chains of activities were identified through a qualitative retrospective analysis of various experiences of emerging disease surveillance and investigation, in the domains of public health, veterinary public health and animal heath, in distinct contexts ranging from a routine investigation to a major sanitary crisis.These analysis resulted in the identification of standard chains of activities that can support a successful implementation of emerging disease surveillance and investigation. These chains of activities were integrated in a standard structure for enhanced emerging animal disease surveillance and investigation capacities.The goal should now be to set up an integrated global system that would routinely implement these chains of activities and allow for the detection and description of any animal disease or threat to help inform prevention and control strategies
L’épidémiologie d’intervention a pour objectif la détection précoce des situations d’alerte sanitaire afin d’apporter une aide à la décision pour le déclenchement d’une réponse visant à en limiter l’impact. Dans le domaine de la santé animale, l’épidémiologie d’intervention se développe sous l’influence d’enjeux sanitaires, économiques et de santé publique. La structuration des activités est nécessaire au développement performant de cette discipline.Dans ce contexte, un modèle pour la structuration opérationnelle de l’épidémiologie d’intervention a été développé selon les principes d’une méthode d’optimisation de la performance reconnue : l’approche processus. L’établissement de ce modèle a reposé sur l’identification des chaînes d’activités (processus) d’une épidémiologie d’intervention performante, adaptée à la santé animale, tout en capitalisant les acquis et les avancées de cette discipline dans le domaine de la santé publique. Ces chaînes d’activités ont été identifiées grâce à l’analyse qualitative rétrospective d’expériences en épidémiologie d’intervention dans différents domaines (santé publique, santé publique vétérinaire, santé animale), en réponse à des contextes variés.Ces analyses rétrospectives ont permis d’identifier des chaînes d’activités vectrices de performance en épidémiologie d’intervention. Ces activités ont été intégrées au modèle proposé pour la structuration opérationnelle de cette discipline.L’objectif serait désormais d’assurer la mise en œuvre des chaînes d’activités identifiées via un système intégré global, à même de détecter et de documenter toute maladie animale, ou menace liée aux animaux, et d’informer la prise de mesures adéquates pour son controle
TH2016PESC1194.pdf (9.45 Mo) Télécharger le fichier
tel-01621815 , version 1 (23-10-2017)
  • HAL Id : tel-01621815 , version 1
Morgane Dominguez. Optimisation de la performance de l’épidémiologie d’intervention en santé animale. Biologie animale. Université Paris-Est, 2016. Français. ⟨NNT : 2016PESC1194⟩. ⟨tel-01621815⟩
366 Consultations
543 Téléchargements
