Complexes homo- et hétéro-nucléaires de manganèse et de métaux alcalino-terreux : vers des modèles du centre de dégagement d'oxygène du photosystème II - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2015
Homo- and heteronuclear complexes of manganese and alkaline-earth metals : towards models of the oxygen-evolving center of photosystem II
This thesis is focused on the development and characterization of new homo- and heteronuclear complexes of manganese and alkaline-earth metals for the modelization of the Mn4CaO5 inorganic cluster of the OEC of photosystem II.New ligands incorporating a varied number of pyridine-carboxylate groups and based on the tris-(2-picolyl)amine and bis-(2-picolyl)ethylamine architectures have been synthesized. These ligands enabled the isolation of Ca2+ and Sr2+ homonuclear complexes as well as heteronuclear MnII–Ca complexes. Part of these species have been characterized (among other models) by Ca XAS spectroscopy, enabling the calibration of this technique for the study of more complex systems such as the OEC.Furthermore, a new family of MnII3M’ (M’ = Li+, Ca2+, Sr2+, Mn2+) tetranuclear complexes has been isolated, based on a trinuclear Mn2+ metallamacrocyclic architecture hosting a M’ cation in the formed cavity. These complexes exhibited an original electrochemical behavior, displaying three successive reversible redox processes in oxidation whose potentials vary depending on the metal M’. These species demonstrated an excellent stability in solution, even at the +III oxidation state of manganese. Similar homonuclear M3M (M = Fe2+, Co2+) complexes have been isolated.Finally, binuclear Mn3+ complexes bridged by oxo ligands have been isolated, as well as their Mn2+ precursors. Moreover, a mixed-valence Mn2+/Mn3+ metallamacrocyclic cluster incorporating calcium has been synthesized, revealing the first example of a manganese(II) bridged by an hydroxo ligand to Ca2+ ions.
Ce mémoire de thèse est consacré au développement et à la caractérisation de nouveaux complexes homo- et hétéronucléaires de manganèse et de métaux alcalino-terreux dans le cadre de la modélisation du cluster inorganique Mn4CaO5 de l’OEC du photosystème II.De nouveaux ligands incluant un nombre variable de groupements pyridine-carboxylates basés sur les architectures tris-(2-picolyl)amine et bis-(2-picolyl)ethylamine ont été synthétisés. Ces ligands ont permis d’isoler de nouveaux complexes homonucléaires avec Ca2+ et Sr2+ et ainsi que des complexes hétéronucléaires MnII–Ca. L’analyse par spectroscopie XAS sur le calcium de certaines de ces espèces (parmi d’autres modèles) a permis de calibrer cette technique et ainsi montrer que le XAS pourrait être utilisé pour sonder le cluster naturel dans les différents états du cycle de Kok.Par la suite, une nouvelle famille de complexes tétranucléaires MnII3M’ (M’ = Li+, Ca2+, Sr2+, Mn2+) a été isolée, reposant sur une base métallomacrocyclique trinucléaire accueillant un cation M’ dans la cavité formée. Ces complexes ont révélé un comportement électrochimique original présentant trois systèmes redox successifs et réversibles dont le potentiel varie avec M’. Ces espèces ont démontré une excellente stabilité en solution, y compris à l’état d’oxydation du manganèse +III. Des complexes homonucléaires M3M (M = Fe2+, Co2+) similaires ont aussi été étudiés.Enfin, des complexes binucléaires de Mn3+ pontés par des ligands oxo ont été isolés, ainsi que leurs précurseurs de Mn2+. Par ailleurs, un exemple de cluster métallomacrocyclique à valence mixte Mn2+/Mn3+ et incorporant du calcium a été obtenu, qui représente le premier exemple d’un manganèse(II) ponté par un ligand hydroxo à deux ions Ca2+.
49617_GEREY_2015_archivage.pdf (30.85 Mo) Télécharger le fichier
tel-01643974 , version 1 (21-11-2017)
  • HAL Id : tel-01643974 , version 1
Bertrand Gerey. Complexes homo- et hétéro-nucléaires de manganèse et de métaux alcalino-terreux : vers des modèles du centre de dégagement d'oxygène du photosystème II. Chimie de coordination. Université Grenoble Alpes, 2015. Français. ⟨NNT : 2015GREAV041⟩. ⟨tel-01643974⟩
280 Consultations
129 Téléchargements
