Modélisation bayésienne et robotique - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Hdr Année : 2017
This document describes my research around Bayesian modeling and robotics. My work started with the modeling of biological processes before evolving towards robotics. In both cases, I was interested in both perception and action. I first proposed a model of human perception of planar surfaces with optic flow which fuses in a single framework two concurrent hypotheses of the literature. I also proposed and compared several models of eye movement selection in a Multiple Object Tracking task. I was able to show that the model with explicit uncertainty was the closest to the subjects eye movements. In robotics, I worked on the state estimation of several robots with classical filtering techniques but also including fusion of multiple sources of information of various nature and characteristics. I also discuss the Iterative Closest Point algorithm for which we proposed a more rigorous method for evaluating the different variants. The last piece of work I present deals with online three-dimensional path planning and execution of a tracked robot with significant climbing capabilities. I conclude this document with perspectives on what I call situated robotics, that is robots not taken in isolation but embedded in a sensorized environment shared with humans.
Ce document décrit mes travaux de recherche autour de la modélisation bayésienne et de la robotique. Mon travail a commencé par la modélisation de processus biologiques avant, dans un deuxième temps, d'évoluer vers la robotique. Dans les deux cas, je me suis intéressé à la fois à la perception et à l'action. J'ai donc proposé un modèle de la perception humaine de plans par le flux optique qui réunit deux hypothèses de la littérature dans un cadre unique. J'ai aussi proposé et comparé différents modèle de la sélection de mouvement oculaire dans une tâche de suivi multi-cibles, et montré que le modèle prenant en compte explicitement l'incertitude proposait des mouvements plus proches de ceux des sujets. Du côté robotique, j'ai travaillé sur l'estimation d'état de plusieurs robots avec des techniques classiques de filtrage mais en incluant la fusion de plusieurs sources d'informations de nature et caractéristiques différentes. Je discute aussi de l'algorithme d'Iterative Closest Point pour proposer une méthode plus rigoureuse d'évaluation des différentes variantes. Le dernier travail que je présente concerne la planification en ligne et l'exécution de chemin pour un robot à chenille avec des capacités de franchissement importantes. Je conclus ce document par des perspectives de travail sur ce que j'appelle la robotique située, c'est-à-dire des robots non plus isolés mais plongés dans un environnement équipé de capteurs et partagé avec des humains.
hdr_colas.pdf (10.91 Mo) Télécharger le fichier
tel-01647934 , version 1 (24-11-2017)
  • HAL Id : tel-01647934 , version 1
Francis Colas. Modélisation bayésienne et robotique. Robotique [cs.RO]. Université de Lorraine, 2017. ⟨tel-01647934⟩
343 Consultations
458 Téléchargements
