Géodynamique et impact de la crise d'érosion et de salinité Messinienne sur les transferts sédimentaires (bassin de Valence, bassin Adriatique) - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2016
Perched basins of Mediterranean Sea : geodynamic, and impact of the Messinian salinity crisis on the sedimentary fluxes (Valencia and Adriatic basins)
Romain Pellen
The geodynamic evolution of the Mediterranean area, especially in the Valencia and Adriatic basins, is strongly influenced by its ante-Neogene history. The localization of existing thresholds at that time, and their impact on the following tectono- sedimentary evolutions still remain largely unknown. In this work, we will try to reconstruct this evolution and better understand the part of these thresholds, in particular during the Messinian Erosional and Salinity Crisis (MESC, 5.96-5.32 Ma). We provide here a complete view of the Neogene sedimentary infilling for the both Valencia and Adriatic basins thanks to a compilation of seismic profiles correlated to industrial boreholes.Our results allow us to individualize the Valence-Provençal domain into three subbasins whose ages, subsidence and crustal nature differ. A new kinematic and geodynamic scenario for the Valencia and Neogene Algerian basins is proposed here. This segmentation provides also information about MESC. We highlight a fully incised-valley system whose length reaches more than 270 km, the latter associated with the development of several system tracts. Overall, these interpretations lets us look the Ebro basin connection paradox from a different angle.The Mesozoic Apulian-Gargano-Pelagosa composite threshold mainly control the Neogene sedimentation in the Adria domain and distinguishes two main depocenters. The propagating of the Albanid and Apennine deformation fronts control also the evolution of vertical movements and the sedimentation. Our results imply that the Messinian period corresponds to a major tectonic and/or kinematic reorganization phase within which the MSC is a superimposed event.
L’évolution géodynamique et physiographique de l’espace Méditerranéen, en particulier au sein des bassins bordiers de Valence et Adriatique, sont intimement liées à l’héritage anté-Néogène. L’identification de la segmentation des bassins et leur implication dans l’histoire tectonique et environnementale au Néogène, en particulier lors de la crise d’érosion et de salinité Messinienne (MESC - 5.96-5.32 Ma), reste cependant méconnus et font l’objet de ce travail de recherche. Afin de les mettre en lumière, nous proposons une vision complète du remplissage sédimentaire Néogène des deux bassins, sur la base d’une compilation de profils sismiques et de forages industriels. Nos résultats illustrent une segmentation du domaine Valence-Provençal en trois sousbassins d’âges, de subsidences et de nature crustales différentes. Un nouveau scénario cinématique est proposé à l’échelle des bassins Valencien et Algérien. Cette segmentation met en lumière lors de la MESC un système complet de vallées incisées fluviatiles long de plus de 270 km. Associé aux différents cortèges sédimentaires, un nouveau regard est jeté sur l’événement Messinien et le paradoxe d’ouverture du bassin de l’Ebre. Au sein du domaine Adria, l’héritage Mésozoïque contrôle en premier lieu les environnements néogènes, où deux dépocentres majeurs se distinguent de part et autre du seuil composite Apulien-Gargano-Pelagosa. La propagation des fronts de déformations Albanide et Apennin se surimpose à cet héritage et contrôle la sédimentation et les mouvements verticaux de ces dépocentres La période Messinienne est alors perçue comme une phase de réorganisation tectonique majeure, cette dernière se surimposant à la MESC.
These-2016-EDSM-Science_de_la_terre-PELLEN_Romain_Vol1.pdf (21.04 Mo) Télécharger le fichier
These-2016-EDSM-Science_de_la_terre-PELLEN_Romain_Vol2_annexes.pdf (472.47 Mo) Télécharger le fichier
Format : Autre
tel-01651341 , version 1 (18-01-2018)
  • HAL Id : tel-01651341 , version 1
Romain Pellen. Géodynamique et impact de la crise d'érosion et de salinité Messinienne sur les transferts sédimentaires (bassin de Valence, bassin Adriatique). Sciences de la Terre. Université de Bretagne occidentale - Brest, 2016. Français. ⟨NNT : 2016BRES0041⟩. ⟨tel-01651341⟩
453 Consultations
135 Téléchargements
