Functional encryption for inner-product evaluations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2017
Chiffrement fonctionnel pour l'évaluation de produits scalaires
Functional encryption is an emerging framework in which a master authority can distribute keys that allow some computation over encrypted data in a controlled manner. The trend on this topic is to try to build schemes that are as expressive possible, i.e., functional encryption that supports any circuit evaluation. These results are at the cost of efficiency and security. They rely on recent, not very well studied assumptions, and no construction is close to being practical. The goal of this thesis is to attack this challenge from a different angle: we try to build the most expressive functional encryption scheme we can get from standard assumption, while keeping the constructions simple and efficient. To this end, we introduce the notion of functional encryption for inner-product evaluations, where plaintexts are vectors ~x, and the trusted authority delivers keys for vectors ~y that allow the evaluation of the inner-product h~x, ~yi. This functionality already offers some direct applications, and it can also be used for theoretical constructions, as inner-product is a widely used operation. Finally, we present two generic frameworks to construct inner-product functional encryption schemes, as well as some concrete instantiations whose security relies on standard assumptions. We also compare their pros and cons.
Le chiffrement fonctionnel est une technique émergente en cryptographie dans laquelle une autorité toute puissante est capable de distribuer des clés permettant d’effectuer des calculs sur des données chiffrées de manière contrôlée. La mode dans ce domaine est de construire des schémas qui sont aussi expressifs que possible, c’est-à-dire du chiffrement fonctionnel qui permet l’évaluation de n’importe quel circuit. Ces contributions délaissent souvent l’efficacité ainsi que la sécurité. Elles reposent sur des hypothèses fortes, très peu étudiées, et aucune construction n’est proche d’être pratique. Le but de cette thèse est d’attaquer ce défi sous un autre angle : nous essayons de construire des schémas de chiffrement fonctionnel les plus expressifs que nous le pouvons en se basant sur des hypothèses standards, tout en conservant la simplicité et l’efficacité des constructions. C’est pourquoi nous introduisons la notion de chiffrement fonctionnel pour l’évaluation de produits scalaires, où les messages sont des vecteurs ~x, et l’autorité peut transmettre des clés correspondants à des vecteurs ~y qui permettent l’évaluation du produit scalaire h~x, ~yi. Cette fonctionnalité possède immédiatement des applications directes, et peut aussi être utilisé dans d’autres constructions plus théoriques, leproduit scalaire étant une opération couramment utilisée. Enfin, nous présentons deux structures génériques pour construire des schémas de chiffrement fonctionnels pour le produit scalaire, ainsi que des instanciations concrètes dont la sécurité repose sur des hypothèses standards. Nous comparons aussi les avantages et inconvénients de chacune d’entre elles.
Bourse-2017-These.pdf (1.59 Mo) Télécharger le fichier
tel-01665276 , version 1 (15-12-2017)
tel-01665276 , version 2 (17-07-2018)
  • HAL Id : tel-01665276 , version 2
Florian Bourse. Functional encryption for inner-product evaluations. Cryptography and Security [cs.CR]. Université Paris sciences et lettres, 2017. English. ⟨NNT : 2017PSLEE067⟩. ⟨tel-01665276v2⟩
587 Consultations
823 Téléchargements
