Claquage Electrique et Optique d'Allotropes du Carbone : Mécanismes et Applications pour le Stockage de Données - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2016
Optical and Electrical Breakdown of Carbon Allotropes : Mechanisms and Applications for Data Storage
Today, data storage applications rely mainly on two types of materials: chalcogenides for optical storage (e.g. Blu-Ray) and silicon for electronic storage (e.g. Flash memory). While these materials have proven to be the most efficient for widespread applications, both have limitations. Recently, with the rise of graphene, carbon allotropes have been studied both for their intrinsic properties and for applications; graphene and other carbon allotropes have very interesting electronic, thermal and mechanical properties that can make these materials more efficient than either chalcogenides or silicon for certain applications. In this thesis, we study the feasibility and potential of the usage of carbon as a data storage material.Firstly, we focus on developing optical data storage. It is found that both continuous-wave and pulsed lasers can be used to induce reversible phase changes in carbon thin films, thus opening the way toward carbon-based data storage. Along the way, several phenomena are discovered, shown and explained by using advanced characterization techniques and thermal modelling.Secondly, we focus on electronic data storage by developing graphene-based memories that are found to switch reliably between two well-separated resistance states for a large number of cycles. To assess the potential of this new technology, we characterize the switching mechanism and develop an electro-mechanical model enabling to predict the best performances attainable: these memories would potentially be much faster than Flash memories while playing the same role (non-volatile storage).
Aujourd’hui, les applications de stockage de données utilisent principalement deux types de matériaux : les chalcogénures pour le stockage optique (e.g. Blu-Ray) et le silicium pour le stockage électronique (e.g. mémoires Flash). Malgré le fait qu’ils se soient avérés les plus efficaces pour des applications répandues, ces matériaux ont des limitations. Récemment, avec la montée en puissance du graphene, les allotropes du carbone ont été étudiés à la fois pour leurs propriétés intrinsèques et pour des applications ; ils ont des propriétés électroniques, thermiques et mécaniques très intéressantes qui peuvent rendre ces matériaux plus efficaces que les chalcogénures ou le silicium pour certaines applications. Dans cette thèse, nous étudions la faisabilité et le potentiel du carbone comme matériau pour le stockage de données.Nous nous concentrons d’abord sur le développement de stockage optique. Nous découvrons que les lasers continus et pulsés peuvent être utilisés pour induire des changements de phase réversibles dans des couches minces de carbone, confirmant la possibilité d’utiliser le carbone comme un matériau pour le stockage optique. De plus, nous découvrons plusieurs nouveaux phénomènes, que nous expliquons en utilisant des techniques de caractérisation avancées et de la modélisation par ordinateur de la propagation thermique dans le carbone.Ensuite, nous nous concentrons sur le stockage de données électronique en développant des mémoires à base de graphene qui peuvent être dans deux états de résistance bien séparés pour un grand nombre de cycles. Pour évaluer le potentiel de cette technologie, on caractérise le mécanisme de changement de résistance et on développe un modèle électromécanique qui permet de prédire les meilleures performances atteignables : ces mémoires ont le potentiel de commuter bien plus rapidement que les mémoires Flash tout en étant non-volatiles.
54219_LOISEL_2016_archivage.pdf (37.2 Mo) Télécharger le fichier
tel-01665811 , version 1 (17-12-2017)
tel-01665811 , version 2 (17-01-2018)
  • HAL Id : tel-01665811 , version 1
Loïc Loisel. Claquage Electrique et Optique d'Allotropes du Carbone : Mécanismes et Applications pour le Stockage de Données. Physique [physics]. Université Paris-Saclay, 2016. Français. ⟨NNT : 2016SACLX021⟩. ⟨tel-01665811v1⟩
346 Consultations
108 Téléchargements
