Towards Trustworthy Online Voting: Distributed Aggregation of Confidential Data - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2017
Confiance dans le vote en ligne : Agrégation distribuée de données confidentielles
Aggregation of values that need to be kept confidential while guaranteeing the robustness of the process and the correctness of the result is necessary for an increasing number of applications. Various kinds of surveys, such as medical ones, opinion polls, referendums, elections, as well as new services of the Internet of Things, such as home automation, require the aggregation of confidential data. In general, the confidentiality is ensured on the basis of trusted third parties or promises of cryptography, whose capacities cannot be assessed without expert knowledge. The ambition of this thesis is to reduce the need for trust in both authorities and technology and explore methods for large-scale data aggregations, that ensure a high degree of confidentiality and rely neither on trusted third parties nor solely on cryptography. Inspired by BitTorrent and Bitcoin, P2P protocols are considered. The first contribution of this thesis is the extension of the distributed aggregation protocol BitBallot with the objective to cover aggregations in P2P networks comprising adversarial peers with fail-stop or Byzantine behaviour. The introduced changes allow eventually to maintain an accurate result in presence of an adversarial minority. The encountered scalability limitations lead to the second contribution with the objective to support large-scale aggregations. Inspired by both BitBallot and BitTorrent, a novel distributed protocol called ADVOKAT is proposed. In both protocols, peers are assigned to leaf nodes of a tree overlay network which determines the computation of intermediate aggregates and restricts the exchange of data. The partition of data and computation among a network of equipotent peers limits the potential for data breaches and reduces the need for trust in authorities. The protocols provide a middleware layer whose flexibility is demonstrated by voting and lottery applications.
L'agrégation des valeurs qui doivent être gardées confidentielles tout en garantissant la robustesse du processus et l'exactitude du résultat est nécessaire pour un nombre croissant d'applications. Divers types d'enquêtes, telles que les examens médicaux, les référendums, les élections, ainsi que les nouveaux services de Internet of Things, tels que la domotique, nécessitent l'agrégation de données confidentielles. En général, la confidentialité est assurée sur la base de tiers de confiance ou des promesses de cryptographie, dont les capacités ne peuvent être évaluées sans expertise. L'ambition de cette thèse est de réduire le besoin de confiance dans les autorités, de même que la technologie, et d'explorer les méthodes d'agrégations de données à grande échelle, qui garantissent un degré élevé de confidentialité et ne dépendent ni de tiers de confiance ni de cryptographie. Inspiré par BitTorrent et Bitcoin, les protocoles P2P sont considérés. La première contribution de cette thèse est l'extension du protocole d'agrégation distribuée BitBallot dans le but de couvrir les agrégations dans les réseaux P2P comprenant des pairs adversaires avec un comportement défaillant ou byzantin. Les changements introduits permettent éventuellement de maintenir un résultat précis en présence d'une minorité adversaire. Les limites de scalabilité rencontrées conduisent à la deuxième contribution dans le but de soutenir les agrégations à grande échelle. Inspiré par BitBallot et BitTorrent, un nouveau protocole distribué appelé ADVOKAT est proposé. Dans les deux protocoles, les pairs sont affectés aux noeuds feuilles d'un réseau de superposition d'une structure arborescente qui détermine le calcul des agrégats intermédiaires et restreint l'échange de données. La partition des données et du calcul entre un réseau de pairs équipotent limite le risque de violation de données et réduit le besoin de confiance dans les autorités. Les protocoles fournissent une couche middleware dont la flexibilité est démontrée par les applications de vote et de loterie.
Thesis.pdf (2.27 Mo) Télécharger le fichier
tel-01675509 , version 1 (04-01-2018)
tel-01675509 , version 2 (24-05-2018)
  • HAL Id : tel-01675509 , version 2
Robert Riemann. Towards Trustworthy Online Voting: Distributed Aggregation of Confidential Data. Cryptography and Security [cs.CR]. Ecole normale supérieure de Lyon, 2017. English. ⟨NNT : ⟩. ⟨tel-01675509v2⟩
562 Consultations
1943 Téléchargements
