OntoApp : a declarative approach for software reuse and simulation in early stage of software development life cycle
OntoApp : une approche déclarative pour la simulation du fonctionnement d’un logiciel dès une étape précoce du cycle de vie de développement
In this thesis, we study several models of collaboration between Software Engineering and Semantic Web. From the state of the art, we propose an approach to the use of ontology in the business application layer. The main objective of our work is to provide the developer with the tools to design, in the declarative manner, a business "executable" layer of an application in order to simulate its operation and thus show the compliance of the application with the customer requirements defined at the beginning of the software life cycle. On the other hand, another advantage of this approach is to allow the developer to share and reuse the business layer description of a typical application in a domain using ontology. This typical application description is called "Application Template". The reuse of the business layer description of an application is an interesting aspect of software engineering. That is the key point we want to consider in this thesis. In the first part of this thesis, we deal with the modeling of the business layer. We first present an ontology-based approach to represent business process and the business rules and show how to verify the consistency of business process and the set of business rules. Then, we present an automatic check mechanism of compliance of business process with a set of business rules. The second part of this thesis is devoted to define a methodology, called personalization, of creating of an application from an "Application Template". This methodology will allow the user to use an Application Template to create his own application by avoiding deadlock and semantic errors. We introduce at the end of this part the description of an experimental platform to illustrate the feasibility of the mechanisms proposed in the thesis. This platform s carried out on a relational DBMS.Finally, we present, in a final chapter, the conclusion, the perspective and other annexed works developed during this thesis.
Dans cette thèse, nous étudions plusieurs modèles de collaboration entre l’ingénierie logiciel et le web sémantique. À partir de l’état de l’art, nous proposons une approche d’utilisation de l’ontologie dans la couche de métier d’une application. L’objectif principal de notre travail est de fournir au développeur des outils pour concevoir la matière déclarative une couche de métier "exécutable" d’une application afin de simuler son fonctionnement et de montrer ainsi la conformité de l’application par rapport aux exigences du client au début du cycle de vie du logiciel. Un autre avantage de cette approche est de permettre au développeur de partager et de réutiliser la description de la couche de métier d’une application dans un domaine en utilisant l’ontologie. Celle-ci est appelée "patron d’application". La réutilisation de la description de la couche de métier d’une application est un aspect intéressant à l'ingénier logiciel. C’est le point-clé que nous voulons considérer dans cette thèse. Dans la première partie de notre travail, nous traitons la modélisation de la couche de métier. Nous présentons d’abord une approche fondée sur l’ontologie pour représenter les processus de métiers et les règles de métiers et nous montrons comment vérifier la cohérence du processus et de l’ensemble des règles de métier. Puis, nous présentons le mécanisme de vérification automatique de la conformité d’un processus de métier avec un ensemble de règles de métier. La deuxième partie de cette thèse est consacrée à définir une méthodologie, dite de personnalisation, de création une application à partir d'un "patron d’application". Cette méthode permettra à l'utilisateur d'utiliser un patron d'application pour créer sa propre application en évitant les erreurs de structures et les erreurs sémantiques. Nous introduisons à la fin de cette partie, la description d’une plateforme expérimentale permettant d’illustrer la faisabilité des mécanismes proposés dans cette thèse. Cette plateforme est réalisée sur un SGBD relationnel.
Origin : Version validated by the jury (STAR)
