Diffraction methods for the crystallography of membrane proteins
Méthodes de diffraction pour la cristallographie des protéines membranaires
In this study the methodological aspects for producing high-resolution crystal structures of membrane proteins were combined and reported here as well as their implication for the concrete biologically-relevant case of structural investigation of transmembrane histidine kinase working principles.In X-ray crystallography protein crystal samples vary in sizes, shapes and diffracting abilities. To be able to collect the diffraction data in the most efficient way the crystal sample should be properly characterised on-axis in every particular case. Raster X-ray scan has been found to be the most viable technique to do so and in this context a method of crystal sample analysis for protein crystallography is presented here which is based on the X-ray mesh scan technique developed at the ESRF. The method estimates the positions, sizes and quality of diffraction of each crystal in the scanned area which could be further useful for the rational design of the data collection process. The performance of the method is demonstrated on several protein crystal samples.Another bottleneck in production of crystal structures of proteins is in commonly known phase problem. The most widespread techniques to deal with the structure that cannot be phased using molecular replacement are SAD or MAD-based experimental phasing. This implies incorporation of various anomalous scatterers to the crystal structure. In the list of available scatterers halides are particularly stood out mostly because their low toxicity and easiness of handling but at the same time their capability of producing anomalous signal. The protocol of cryo-soaking of the protein crystals in halide-containing solutions has shown to be successful on soluble protein structures. In the current study this protocol was tested on four different crystal structures of membrane proteins. The presented findings state and further support experimentally that iodide could be easily and successfully used for addressing the phase problem in the case of membrane protein crystal structures.Sensor histidine kinases are ones of the most common transmembrane receptors present in all kingdoms of life. The understanding of transmembrane signalling principles of sensor histidine kinases is a fundamental question that currently remains unanswered. In order to get to the idea of which structural changes provide the transmission of the signal across the lipid membrane in this work the crystal structure of the truncated construct of the histidine kinase NarQ of Escherichia coli – a sensor of nitrates/nitrites – which contains periplasmic sensor domain, transmembrane helices and HAMP domain at the cytoplasmic side was determined in the ligand-bound and mutated apo states. The presented structures provide an insight on the conformational changes occurring in the transmembrane domain and in the downstream HAMP domain during the ligand-induced signal transduction. The progress of the structural investigation was greatly enhanced by the involvement of the methodological findings presented in this work. This impact and as well the prospective outcomes of this work to both methodological and applied disciplines of structural biology and X-ray crystallography in particular are discussed.
Dans cette étude, les aspects méthodologiques pour la production de structures cristallines à haute résolution des protéines membranaires ont été combinés et rapportés ici, ainsi que leur implication pour le cas biologique concret d'étude structurale des principes de fonctionnement de l'histidine kinase transmembranaire.Dans la cristallographie de rayons X, les échantillons de cristaux de protéines varient selon les tailles, les formes et les capacités de diffraction. Pour pouvoir collecter les données de diffraction de la manière la plus efficace, l'échantillon de cristaux doit être correctement caractérisé dans chaque cas particulier. L'analyse raster par rayons X est considérée comme la technique la plus viable pour le faire et dans ce contexte, une méthode d'analyse des échantillons de cristaux pour la cristallographie des protéines est présentée ici, qui est basée sur la technique de balayage des mailles par rayons X développée à l'ESRF. La méthode estime les positions, les tailles et la qualité de la diffraction de chaque cristal dans la zone scannée qui pourrait être plus utile pour la conception rationnelle du processus de collecte de données. La performance de la méthode est démontrée sur plusieurs échantillons de cristaux de protéines.Un autre goulot d'étranglement dans la production des structures cristallines des protéines est un problème de phase communément connu. Les techniques les plus répandues pour traiter la structure qui ne peut pas être résolue avec le remplacement moléculaire sont les techniques de mise en phase expérimentales basées sur SAD ou MAD. Cela implique l'incorporation de divers diffuseurs anormaux à la structure cristalline. Dans la liste des diffuseurs disponibles, les halogénures se distinguent surtout principalement par leur faible toxicité et leur facilité de manipulation, mais en même temps leur capacité à produire un signal anormal. Le protocole de cryo-trempage des cristaux de protéines dans des solutions contenant des halogénures s'est avéré efficace sur les structures protéiques solubles. Dans l'étude actuelle, ce protocole a été testé sur quatre structures cristallines différentes des protéines membranaires. Les résultats présentés indiquent et soutiennent de manière expérimentale que l'iodure pourrait être facilement et efficacement utilisé pour résoudre le problème de phase dans le cas des structures de cristaux de protéines membranaires.Le capteur histidine kinases est l'un des récepteurs transmembranaires les plus communs présents dans tous les royaumes de la vie. La compréhension des principes de signalisation transmembranaire de l'histidine kinases sensorielle est une question fondamentale qui reste actuellement sans réponse. Pour arriver à l'idée de quels changements structurels fournissent la transmission du signal à travers la membrane lipidique dans ce travail, la structure cristalline de la construction tronquée de l'histidine kinase NarQ d'Escherichia coli – un capteur de nitrates/nitrites – qui contient le capteur périplasmique, les hélices transmembranaires et le domaine HAMP au niveau du côté cytoplasmique a été déterminée dans les états lié à un ligand et l'apo muté. Les structures présentées fournissent un aperçu des changements de conformation qui se produisent dans le domaine transmembranaire et dans le domaine HAMP en aval pendant la transduction du signal induite par le ligand. L'avancement de la recherche structurelle a été grandement renforcé par l'implication des résultats méthodologiques présentés dans ce travail. Cet impact et, en particulier, les résultats prospectifs de ce travail aux disciplines méthodologiques et appliquées de la biologie structurale et de la cristallographie des rayons X en particulier sont discutés.
