Analysis of a protein, biomarker of nerve agents poisoning : development of immunosorbents and enzymatic reactors, coupled on-line with liquid chromatography and mass spectrometry
Analyse d'une protéine biomarqueur d'intoxication par des agents neurotoxiques : développement d'immunoadsorbants et de réacteurs enzymatiques, couplés en ligne à la chromatographie liquide et à la spectrométrie de masse
The objective of this work was to develop a sample treatment method for the LC-MS2 analysis of adducts formed between organophosphorus nerve agent (OPNA) and butyrylcholinesterase, a plasmatic protein. In order to fully automate the analytical process, an immunoextraction step was coupled to an enzymatic digestion reactor (IMER), followed by microLC-MS2 analysis to detect the OPNA-peptide adduct. First, the synthesis of pepsin-based IMER was optimized. The most powerful pepsin-based IMER was applied to the digestion of HuBuChE to generate the peptide used as biomarker of OPNA intoxication that was further analyzed by nanoLC-MS2. This pepsin-based IMER was then integrated into a microLC-MS2 analytical system, allowing the on-line digestion of HuBuChE and the analysis of the target peptide. In a second step, a selective extraction method was developed by immobilizing anti-HuBuChE antibodies on a solid support, called immunosorbent. The immunoextraction protocol was developed and the immunosorbents were characterized in terms of selectivity and extraction yield before being coupled to the IMER. The feasibility of the coupling was clearly demonstrated and this automatable device was used for the analysis of HuBuChE from human plasma, spiked with OPNA. This allowed the fast and sensitive detection of OPNA-BuChE adducts in very small amounts of plasma.
L'objectif de ce travail était de développer une méthode de traitement de l'échantillon permettant l'analyse par LC-MS2 d'adduits formés entre des composés neurotoxiques organophosphorés (OPNA) et la butyrylcholinesterase, protéine plasmatique. En vue d'une automatisation totale du processus analytique, une étape d'immunoextraction a été couplée à un réacteur de digestion enzymatique (IMER), suivie d'une analyse par microLC-MS2 afin de détecter le peptide adduit par l'OPNA. Tout d'abord, la synthèse d'IMER de pepsine a été optimisée. L'IMER le plus performant a été appliqué à la digestion de la BuChE afin d'analyser le peptide biomarqueur d'intoxication, par nanoLC-MS2. Un IMER de pepsine, de dimensions supérieures a pu être rapidement intégré à un système d'analyse microLC-MS2, permettant la digestion de la BuChE et l'analyse en ligne du peptide cible. Dans un second temps, une méthode d'extraction sélective a été développée par immobilisation de différents anticorps anti-BuChE sur un support solide appelé immunoadsorbant. Le protocole d'immunoextraction a été mis au point, puis les immunoadsorbants ont été caractérisés en termes de sélectivité et de rendement d'extraction avant d'envisager son couplage au digesteur enzymatique. La faisabilité du couplage a pu être clairement démontrée et ce dispositif automatisable a été appliqué à l'analyse de la BuChE de plasma humain, dopé par des OPNA. Cela a permis la détection rapide et sensible des adduits OPNA-BuChE, à partir de très faibles quantités de plasma.
