Vésicules lipidiques biomimétiques décorées par un assemblage multicouche nanocristaux de cellulose/xyloglucane : élaboration et caractérisation mécanique - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2016
Biomimetitc lipidic vesicles coated with a cellulose nanocrystals/xyloglucan multilayer assembly : elaboration and mechanical characterization
Unlike their animal counterparts, plant cells are surrounded by a thin polysaccharide-rich envelop called the primary wall, in which the main load-bearing structure is a network of cellulose microfibrils tethered by hemicellulose. This work aims at designing plant cell wall mimicking capsules that could be used as a model system in the mechanical characterization of this natural material. To do so, we used giant unilamellar vesicles with an average diameter of 20 µm as a template for the layer-by-layer deposition of cellulose nanocrystals (the microfibrils sub-elements) and xyloglucan (the most common hemicellulose) up to ten bilayers, the resulting capsules being characterized by confocal microscopy. Their deformation behaviour under osmotic stress could be observed : deflation of the capsules led to various morphologies, some of them similar to what is observed for thin deflated shells of isotropic material, while their response to swelling resembled that of a viscoelastic material. Nano-indentation experiments were eventually performed using an atomic force microscope to probe the stiffness of the capsules wall. Their Young’s modulus could be deduced from the force-depth curves and found to be in the 6-18 MPa range, which is in the same order of magnitude of values obtained with similar measurements done on natural plant cell walls.
Contrairement à leurs homologues animales, les cellules végétales sont entourées d’une fine enveloppe de polysaccharides appelée paroi primaire, dont la principale structure portante est un réseau de microfibrilles de cellulose reliées entre elles par des hémicelluloses. L’objectif de ce travail est de mettre au point des capsules biomimétiques de la paroi végétale qui puissent servir de système modèle dans l’étude des propriétés mécaniques de ce matériau naturel. Pour ce faire, des vésicules géantes unilamellaires d’un diamètre moyen de 20 µm ont été utilisées comme support de dépôts couche-par-couche de nanocristaux de cellulose (les sous-éléments des microfibrilles) et de xyloglucane (l’hémicellulose la plus répandue) jusqu’à une dizaine de bicouches, les capsules ainsi obtenues ayant été caractérisées par microscopie confocale. Leur comportement en déformation en réponse à une pression osmotique a pu être observé : leur dégonflement a donné lieu à l’apparition de diverses morphologies dont certaines sont similaires aux formes de coques minces de matériau isotrope dégonflées, tandis que leur comportement en gonflement est comparable à la réponse d’un matériau viscoélastique. Enfin, des expériences de nano-indentation par microscopie à force atomique ont été effectuées pour mesurer la rigidité de la paroi des capsules. Leur module d’Young a pu être déduit des courbes de force-déformation et s’avère être compris entre 6 et 18 MPa, ce qui est du même ordre de grandeur que les valeurs obtenues par des mesures similaires effectuées sur des parois végétales naturelles.
RADAVIDSON_2016_diffusion.pdf (61.39 Mo) Télécharger le fichier
tel-01687288 , version 1 (18-01-2018)
  • HAL Id : tel-01687288 , version 1
Harisoa Radavidson. Vésicules lipidiques biomimétiques décorées par un assemblage multicouche nanocristaux de cellulose/xyloglucane : élaboration et caractérisation mécanique. Polymères. Université Grenoble Alpes, 2016. Français. ⟨NNT : 2016GREAV051⟩. ⟨tel-01687288⟩
265 Consultations
53 Téléchargements
