Crosstalk entre la kinase LKB1 et l'arginine methyltransferase PRMT5 dans le cancer du sein - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2017
Crosstalk between the kinase LKB1 and the arginine methyltransferase PRMT5 in breast cancer
Hanine Lattouf
  • Fonction : Auteur
  • PersonId : 785832
  • IdRef : 223622397
Protein arginine methyltrasferase 5 is the major type II arginine methyltransferase in humans. It symmetrically dimethylates arginine residues on target proteins in both the cytoplasm and the nucleus. PRMT5 was reported to be an oncoprotein implicated in anchorage independent growth and tumor progression. So far, it has been involved in various cancers such as ovarian cancer, lung cancer and colon cancer, but its expression pattern in breast cancer has not been deeply studied. In this thesis project, we analyzed PRMT5 expression in a cohort of 440 breast tumor samples and we found that its nuclear expression is a good prognosis factor, mainly in ERa-positive tumors. Interestingly, our clinical results analysis showed that PRMT5 expression is correlated with the serine/threonine kinase LKB1, suggesting a relationship between both proteins. Several in vitro and in cellulo approaches gave evidence that PRMT5 and LKB1 interact directly in the cytoplasm of mammary epithelial cells. Moreover, although PRMT5 is not able to methylate LKB1, we found that PRMT5 is a bona fade substrate for LKB1. We next identified Thr132, 139 and 144 residues as target sites for phosphorylation, located in the TIM barrel domain of PRMT5. Interestingly, the Thr139/144 mutation to alanine decreased drastically PRMT5 methyltransferase activity, probably due to the loss of PRMT5 interaction with regulatory proteins such as MEP50, pICLn and RiOK1. In addition, the modulation of LKB1 expression modifies PRMT5 enzymatic activity, highlighting a new regulatory mechanism mediated by the discovered posttranslational modification of this arginine methyltransferase
La protéine arginine méthyltransférase 5 est la majeure arginine méthyltransférase de type II chez les mammifères, responsable de la génération de la majorité des arginines protéiques symétriquement diméthylées. Elle est impliquée dans divers processus oncogéniques tel que la progression tumorale et la croissance indépendante de l'ancrage. PRMT5 est surexprimée dans plusieurs cancers comme le cancer de l'ovaire, des poumons et du colon. Cependant, son expression dans le cancer du sein n'est pas assez étudiée. Dans ce projet de thèse, nous avons analysé l'expression de PRMT5 dans une cohorte de 440 tumeurs mammaires. Nos résultats montrent que son expression nucléaire est un facteur de bon pronostic, notamment dans les tumeurs ERa-positives. Nous avons aussi mis en évidence une corrélation entre PRMT5 et la sérine/thréonine kinase LKB1, suggérant un lien entre ces deux protéines. Plusieurs approches in vitro et in cellulo nous ont permis de démontrer que PRMT5 et LKB1 interagissent dans le cytoplasme des cellules mammaires épithéliales. Bien que PRMT5 soit incapable de méthyler LKB1, nous avons montré pour la première fois que PRMT5 est un substrat de cette kinase. Nous avons par la suite identifié les Thr132, 139 et 144 comme cibles de la phosphorylation, au niveau du tonneau TIM en N-terminal de PRMT5. La mutation des thréonines T139/144 en alanine diminue significativement l'activité de PRMT5, probablement suite à une perte de son interaction avec des protéines régulatrices comme MEP50, pICLn et RiOK1. De plus, la modulation de l'expression de LKB1 altère l'activité de PRMT5, témoignant d'un nouveau mécanisme de régulation médié par la phosphorylation identifiée
TH2017LATTOUFHANINE.pdf (6.14 Mo) Télécharger le fichier
tel-01688844 , version 1 (19-01-2018)
  • HAL Id : tel-01688844 , version 1
Hanine Lattouf. Crosstalk entre la kinase LKB1 et l'arginine methyltransferase PRMT5 dans le cancer du sein. Cancer. Université de Lyon; École doctorale des Sciences et de Technologie (Beyrouth), 2017. Français. ⟨NNT : 2017LYSE1252⟩. ⟨tel-01688844⟩
363 Consultations
213 Téléchargements
