Rôle des inégalités sociales dans la prise en charge et la survie des lymphomes non hodgkiniens en population générale - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2017
Social inequalities impacts of care management and survival in patients with non-hodgkin lymphoma
Due to the addition of innovative treatment, survival of non-Hodgkin lymphoma (NHL) increased during the last decade. Nevertheless, disparities persist, suggesting the role of certain factors as socio-economic factors and disparities in the access or the quality of healthcare.Between 2002 and 2008, 1798 Diffuse Large B-cell (DLBCL) and follicular lymphomas werediagnosed in 3 hematological malignancies specialized registries (Basse-Normandie, Côted'Or and Gironde). Important territorial disparities between the 3 registries areas were observed regarding the place of care, the delay of treatment initiation or the survival whatever the age while there was no association with the deprivation score (EDI).The survival improved during the study period. This positive trend could be explained by the use of immunotherapy as 1st line therapy. The geographical area where the patient was diagnosed, the medical specialization (onco-hematology vs others departments) are independently associated with a better 5-years survival whatever the age.Finally, the improvement of the survival in elderly (especially 75-84 years) could be explained by better work up (higher TEP scan use leading to "upstaging") and thus to use more aggressive therapies. Also, the travel time was associated with the place of care and the survival, with a poorer prognosis for patients living more than 15 min from the closest reference center. Despite therapeutic advances, various non biological factors can affect the prognosis ofpatients with lymphomas. The notion of lymphoma-specific expertise seems to be essential to achieve optimal DLBCL care management and reopen the debate of centralization of NHLpatients care in hematology/oncology departments.
La survie des lymphomes non hodgkiniens (LNH) en population générale s'est améliorée durant la dernière décennie. Pourtant, des disparités persistent, suggérant le rôle de certains facteurs comme les facteurs socio-économiques et des inégalités dans l’accès ou la qualité des soins.Entre 2002 et 2008, 1798 LNH diffus à grandes cellules B et folliculaire ont été diagnostiqués dans 3 registres spécialisés en hématologie (Basse Normandie, Côte d’Or et Gironde). De fortes inégalités territoriales entre les 3 zones registres sont observées concernant le lieu de leur prise en charge, les délais d'initiation au traitement ou la survie, mais aucune association entre le score de défavorisation (EDI) et ces trois critères n'a été mise en évidence.La survie s'est améliorée durant la période d'étude. Cette tendance positive peut être expliquée par l’usage de l'immunothérapie en 1ère ligne. La zone géographique de diagnostic,la spécialité médicale (onco-hématologie vs autres) sont indépendamment associées à une meilleure survie à 5 ans quel que soit l’âge. Enfin, l'amélioration de la survie chez les patients âgés (75-84 ans en particulier) peut s'expliquer par un bilan initial plus complet (TEP scan entrainant un « upstaging ») suivi de traitements plus agressifs.Le temps de déplacement était associé au lieu de prise en charge et à la survie, avec un pronostic défavorable des patients résidant à plus de 15 minutes du centre de référence le plus proche.Malgré les avancées thérapeutiques, de nombreux facteurs non biologiques peuvent affecter le pronostic des patients atteints de LNH. L'expertise des équipes prenant en charge ces maladies semble primordiale pour obtenir une prise en charge optimale.
LE_GUYADER_SANDRA_2017.pdf (6.66 Mo) Télécharger le fichier
tel-01689330 , version 1 (22-01-2018)
  • HAL Id : tel-01689330 , version 1
Sandra Le Guyader-Peyrou. Rôle des inégalités sociales dans la prise en charge et la survie des lymphomes non hodgkiniens en population générale. Santé publique et épidémiologie. Université de Bordeaux, 2017. Français. ⟨NNT : 2017BORD0622⟩. ⟨tel-01689330⟩
449 Consultations
422 Téléchargements
