Architectured materials for transpiration cooling : application to combustion chambers
Matériaux architecturés pour refroidissement par transpiration : application aux chambres de combustion
In order to cool aero-engine combustion chambers as efficiently as possible, there is today a special interest given to transpiration cooling technology. The cooling air flows through a porous liner in which a large amount of heat can be exchanged by convection. The air injection could then take benefit of the pore distribution to form a more homogeneous protective boundary layer.Partially sintered metallic materials are potential candidates to form these porous liners. The present work focuses on internal heat transfers. It aims to develop a methodology capable of highlighting the most adapted partially sintered architectures to this kind of application.During transpiration cooling, flows and heat transfers are governed by some effective material properties which depends on the porous architecture: the effective solid phase thermal conductivity, the volumetric heat transfer coefficient and the permeability properties. Thanks to experimental works and numerical studies on samples digitized by X-ray tomography, simple relationships are first developed between the effective material properties of partially sintered materials and their architectural parameters. The porosity, the specific surface area and the powder type are selected to predict the effective properties.These relationships are finally integrated into a heat transfer model predicting the thermal performance of a design at working engine conditions. A multi-objective optimization and an analysis of the optimal designs highlight some architectures as being potentially interesting for transpiration cooling. Materials with a low porosity and made of large irregular powders seem to ensure the best trade-off among the different criteria taken into consideration.
Dans l’optique de refroidir les parois des chambres de combustion aéronautiques le plus efficacement possible, un intérêt particulier est aujourd’hui porté à la technologie de refroidissement par transpiration. L’air de refroidissement s’écoule au travers d’une paroi poreuse dans laquelle une grande quantité de chaleur est échangée par convection. L’éjection de l’air profite ensuite de la distribution des pores pour former une couche limite protectrice relativement homogène.Les matériaux métalliques obtenus à partir de poudres partiellement frittées sont de bons candidats pour former ces parois poreuses. Ce travail se focalise sur les échanges internes et consiste à développer une méthodologie permettant de dégager les architectures partiellement frittées les plus adaptées à ce type d’application.L’écoulement et les échanges de chaleur lors du refroidissement par transpiration sont régis par quelques propriétés effectives des matériaux qui sont fonction de l’architecture : la conductivité thermique effective, le coefficient de transfert convectif volumique et les propriétés de perméabilité. A l’aide de travaux expérimentaux ou d’études numériques sur des échantillons numérisés par tomographie aux rayons X, des relations simples entre les propriétés effectives des matériaux partiellement frittés et leurs paramètres architecturaux sont tout d’abord développées. La porosité, la surface spécifique et le type de poudre utilisé sont retenus pour prédire les paramètres effectifs.Ces relations sont finalement intégrées dans un modèle de transfert de chaleur prédisant la performance d’une solution dans les conditions de fonctionnement du moteur. Une optimisation "multi-objectifs" et une analyse des designs optimaux permettent alors de mettre en valeur quelques architectures montrant un fort potentiel pour des applications de refroidissement par transpiration. Des matériaux peu poreux formés à partir de larges poudres irrégulières semblent assurer le meilleur compromis entre tous les critères pris en compte.
