Localiser une archive glaciaire de 1.5 millions d'années par une approche multi-modèles - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2017
Multiple ice flow modelling to locate an old-ice coring site
Antarctic ice is an exceptional archive of ancient atmospheric air. The oldest available ice archive (800 ka) is not old enough to study a main climatic transition that occurred between 1.2 Ma and 0.9 Ma (mid-Pleistocene transition). Locating a future old-ice drill site is now one of the main goal of the ice-core community. In the region of Dome C, several old-ice targets have required characteristics, from a thermal and mechanical point of view, to hosts very old ice. The goal of this work is to precisely locate suitable coring sites, using several glaciological models. First a 1D heat model to compute the local geothermal flux, that make us confident in the fact that bedrock heights have been free of basal melting for at least the last 800 ka. It is very likely that such sites are able to host a 1.5 Ma ice archive. Second, a 3D ice flow model, to describe the ice trajectories from the ice surface to the bed. Drilling less than 10 km from the surface ridge mimimizes the risks of stratigraphic disturbance, and drilling on the flanks of the bed relief - and not on its top - is mandatory to ensure a sufficient age resolution. Third, a 1D dating model constrained by isochrones let us describe the distribution of basal ages and age resolutions compatible with observed isochrones, and assess the risk of success or failure of the drilling. With currently available data and modelling tools, two drilling sites are proposed that are located 37 km from Dome C, at which 1.5 Ma-old ice is very likely to be archived in required conditions and with sufficient resolution.
Les glaces de l'Antarctique constituent un matériau d'archivage unique pour garder la trace de l'atmosphère du passé. La plus ancienne archive glaciaire disponible (800 ka) ne permet malheureusement pas d'étudier une transition climatique majeure qui s'est déroulé entre 1.2 Ma et 0.9 Ma (transition du mi-Pleistocène). Localiser un site ayant permis la conservation d'une glace aussi ancienne est donc un enjeu majeur au sein de la communauté des carottes de glace. Plusieurs régions autour du Dôme C présentent de bonnes caractéristiques d'un point de vue thermique et mécanique. Le but de ces travaux est d'identifier précisément des sites propices à un archivage de long terme, en utilisant différents modèles successifs. D'abord un modèle thermique 1D, qui permet de calculer le flux géothermique local, et d'affirmer que les hauteurs du socle sont exemptes de fusion depuis au moins 800 ka. Ensuite un modèle 3D d'écoulement, qui permet la description des trajectoires des particules de glace depuis la surface jusqu'au socle. Pour minimiser les perturbations stratigraphiques, il conviendra de placer le site de forage proche de la crête, et pour assurer une résolution suffisante le site ne devra pas se trouver à l'aplomb du sommet du relief basal, mais sur son flanc. Enfin, on utilise un modèle de datation 1D contraints par les isochrones, pour connaître la distribution des âges basaux et résolutions compatibles avec les isochrones observées, et estimer les risques de succès ou d'échec du forage. On propose deux sites de forage distants de 37 km de Dôme C, pour lesquels la présence de glace exploitable de 1.5 Ma et d'une résolution suffisante est hautement probable.
PASSALACQUA_2017_diffusion.pdf (50.01 Mo) Télécharger le fichier
tel-01690458 , version 1 (23-01-2018)
tel-01690458 , version 2 (23-01-2018)
  • HAL Id : tel-01690458 , version 1
Olivier Passalacqua. Localiser une archive glaciaire de 1.5 millions d'années par une approche multi-modèles. Glaciologie. Université Grenoble Alpes, 2017. Français. ⟨NNT : 2017GREAU024⟩. ⟨tel-01690458v1⟩
219 Consultations
30 Téléchargements
