Improvement of biostratigraphic and paleoenvironmental reconstruction tools based on cretaceous dinoflagellate cysts from the tethys and the atlantic - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2016
Amélioration du biostratigraphique et outils de reconstruction paléoenvironnementaux basés sur les kystes dinoflagellés crétacés de la Téthys et de l'Atlantique
In the first chapter, dinocysts are used to recognize the Upper Cretaceous and Paleocene stage boundaries in the ODP Hole 959D, on the Côte d’Ivoire–Ghana transform margin. The comparison of my own results with two previous studies of the same cores highlights uncertainties of biostratigraphic approach when dinocyst markers have low occurrence frequencies. The second chapter analyzes the dinocyst distribution along an inshore-offshore transect on the western Iberian Margin during the Albian. Contrasting the dinocyst occurrence data with the sedimentological and paleontological data allow identifying dinocyst associations with common environmental preferences and tolerances. The main factors contributing to the dinocyst distribution are the stability and predictability gradient and the nutrient availability. Paleoceanographic and paleogeographic evolution of the western Iberian margin during the Albian are clearly recorded in the spatiotemporal occurrence patterns of dinocyst associations. The third chapter compares Aptian dinocyst distribution from the Central Atlantic and northwestern Tethys. It is used to test the methodology and the paleoenvironmental preferences of dinocyst issued from the second chapter. The recognized paleoenvironmental preferences and tolerances of the Aptian dinocysts precisely match those proposed for the Albian species. The Aptian dinocyst associations reflect the evolution of carbonate platforms of both the Southern Provence Basin and the western Iberian margin, combined with the sedimentary organic matter allows the identification of regional and global oceanic changes; the demise of carbonate platforms, the OAE 1a and the Fallot level.
Dans le premier chapitre, les dinokystes sont utilisés pour caractériser les étages du Crétacé supérieur et le Paléocène dans puits ODP 959D, foré sur la marge de Côte d'Ivoire-Ghana. La comparaison de nos résultats avec deux études antérieures montre des conflits de position des limites d'étages chaque fois que les marqueurs biostratigraphiques sont des formes rares.Le deuxième chapitre analyse la distribution des dinokystes albiens le long d'un transept côte-large sur la marge ouest ibérique. La comparaison des données des dinokystes avec celles de sédimentologie et de paléontologie permet d'identifier des groupes d'espèces qui ont des préférences et tolérances environnementales communs. Les principaux facteurs contrôlant la distribution des dinokystes sont le gradient de stabilité et de prédictibilité et la disponibilité des nutriments. L'évolution paléo-océanographique et paléo-géographique de la marge ouest ibérique au cours de l'Albien est clairement enregistrée par les associations de dinokystes.Le troisième chapitre compare les répartitions des dinokystes aptiens de l'Atlantique central et du nord-ouest de la Téthys. Ce chapitre teste la méthodologie et les préférences paléo-environnementales des dinokystes obtenus pour l'Albien. Les résultats de l'étude de l'Aptien correspondent précisément à ceux de l'Albien. Les associations de dinokystes enregistrent l'évolution des plates-formes carbonatées dans les régions étudiées, la confrontation avec les donnés de la matière organique sédimentaire permet l'identification des changements océaniques mondiaux et régionaux ; la disparition des plates-formes carbonatées, l'OAE 1a et le niveau Fallot.
2016PA066180.pdf (14.78 Mo) Télécharger le fichier
tel-01691423 , version 1 (24-01-2018)
  • HAL Id : tel-01691423 , version 1
Raquel Sánchez Pellicer. Improvement of biostratigraphic and paleoenvironmental reconstruction tools based on cretaceous dinoflagellate cysts from the tethys and the atlantic. Earth Sciences. Université Pierre et Marie Curie - Paris VI; Universidad de Zaragoza (Espagne), 2016. English. ⟨NNT : 2016PA066180⟩. ⟨tel-01691423⟩
213 Consultations
330 Téléchargements
