Amélioration et compréhension du mécanisme d'activation de l'alliage FeTi dopé avec de l'hafnium, pour le stockage de l'hydrogène - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2017
Enhancement and study of activation process of FeTi alloy doped with hafnium, for hydrogen storage
The issue of the first hydrogenation (i.e. activation process) of the intermetallic FeTi for the storage of hydrogen is often a brake for its use in industry. The challenge lies in the design of a "new material" whose first hydrogenation is carried out under the same conditions of moderate temperature and pressure, as during reversible absorption. Efficient solutions are to use a doping element and/or mechanical alloying process. In this work, we propose to use hafnium as a dopant. This project completes the studies that have been carried out on zirconium (e.g. commercial zirconium always contains a certain amount of hafnium). The addition of a small amount of hafnium induces the formation of a secondary phase, "rich" in hafnium and iron. Thanks to the presence of this phase, the kinetics of activation process is improved, without prior heat treatment. The activation process consists of a single step, when the particle size is small. However, a second step appears, for particles bigger than 0.5 mm. The mechanical alloying allowed the formation of the main phase FeTi, and also enhanced the activation process. An accurate control of deposition conditions allow us to design a ″model″ material by magnetron sputtering as thin layers. This ″model″ material can be used to study and understand the hydrogen diffusion, at the interface of the matrix (FeTi) and the dopant (Zr or Hf).
La problématique de la première absorption (i.e. étape d’activation) de l’intermétallique FeTi, pour le stockage de l’hydrogène est souvent un frein pour son industrialisation. Le challenge réside dans la conception d’un « nouveau matériau » dont la première étape d’hydrogénation, s’effectue dans les mêmes conditions de température et de pression modérées, que lors de l’hydrogénation réversible. Une solution est de faire appel aux performances d’un élément dopant et/ou à la technique du broyage mécanique. Dans ce manuscrit, nous proposons l’utilisation de l’hafnium comme dopant. Ce projet complète les études qui ont été effectuées sur le zirconium (e.g. le zirconium commercial contient toujours une certaine quantité d’hafnium). L’ajout d’une faible quantité d’hafnium induit la formation d’une phase secondaire, « riche » en hafnium et en fer. Grâce à la présence de cette phase, la cinétique de première absorption est considérablement améliorée, et ce, sans traitement thermique préalable. L’étape d’activation comprend un seul mécanisme lorsque la taille des particules est faible. A contrario, un second mécanisme est mis en évidence, pour des particules de taille supérieure à 0,5 mm. La mécanosynthèse a permis non seulement d’obtenir la phase principale FeTi, mais aussi de favoriser la première absorption d’hydrogène. Des paramètres d’élaboration méticuleusement optimisés ont rendu possible la conception d’un matériau « modèle », par pulvérisation cathodique magnétron, sous forme de couche mince. Ce matériau modèle pourrait servir à étudier et à comprendre la diffusion de l’hydrogène à l’interface de la matrice FeTi et du dopant Zr ou Hf.
RAZAFINDRAMANANA_VOLATIANA_2017.pdf (8.54 Mo) Télécharger le fichier
tel-01708548 , version 1 (13-02-2018)
  • HAL Id : tel-01708548 , version 1
Volatiana Razafindramanana. Amélioration et compréhension du mécanisme d'activation de l'alliage FeTi dopé avec de l'hafnium, pour le stockage de l'hydrogène. Matériaux. Université de Bordeaux; Université du Quebec à Trois-Rivières. Bibliothèque, 2017. Français. ⟨NNT : 2017BORD0907⟩. ⟨tel-01708548⟩
287 Consultations
269 Téléchargements
