Compréhension et caractérisation multi-échelle de la rupture interfaciale d'assemblages collés (colle crash - tôle galvanisée) pour l'automobile - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2017
Understanding and multi-scale characterization of the interfacial failure of adhesively bonded assembly for automotive industry
Jean Legendre
  • Fonction : Auteur
  • PersonId : 786141
  • IdRef : 224251074
The single lap-shear test is widely used by carmakers to characterize the adhesion of bonded joints. Two criteria govern the validation of the adhesion properties in the bonded joints: the shear strength and the failure mode which has to be cohesive. However, in some special cases, particularly when thin mild galvanized steel substrates were bonded with structural toughened adhesive, an interfacial pattern is obtained instead of cohesive failure. So the bonded assembly is not accepted even if its shear load at failure is high. A better understanding of the interfacial failure is required to adapt the carmakers specifications. The first objective of the PhD thesis was to analyze the critical phenomenon which favor the interfacial failure during single lap test. Substrate rigidity has significant effect on the failure pattern, because it influences the kinematic of deformation of the sample (rotation, steel plasticity, edge effect). Steel plasticity has been identified as a key factor for interfacial failure. The galvanized coating of the steel has a heterogeneous structure, which generate significant heterogeneous strain that could damage the interface. The second objective was to characterize the strength of the substrate-adhesive interface. Two methods have been proposed. The first one enable to measure the strength of an interface which homogeneous loading without edge effect (modified Arcan test). In the second method, the interface capability to resist to edge effects has been assessed. Thus, three different interfaces have been characterized using a three point bending test and thanks to an optical microscopy in situ analysis.
L’essai de type simple recouvrement est très largement utilisé dans l’industrie automobile pour évaluer la compatibilité entre une tôle d’acier et une colle. Dans ce cadre, deux critères de validation ont été définis par les constructeurs automobiles : un chargement à rupture minimum, et un facies de rupture cohésif. La rupture au niveau de l’interface colle/acier (rupture interfaciale), ne permet pas d’attester d’une bonne adhésion entre la colle et la tôle, elle n’est donc pas acceptée. Ainsi dans certains cas, l’assemblage n’est pas validé à cause de son faciès de rupture, même s’il démontre une résistance mécanique élevée. Une meilleure compréhension du phénomène de rupture interfaciale permettrait d’adapter le cahier des charges des constructeurs automobiles. Le premier objectif de la thèse a été de comprendre les mécanismes de rupture qui peuvent engendrer une rupture interfaciale. Des études expérimentales et numériques ont montré que la rigidité de la tôle a une forte influence sur la cinématique de déformation de l’éprouvette (rotation, plasticité de la tôle, effet de bords), et qu’elle influe beaucoup sur le faciès de rupture. La déformation plastique de la tôle semble être un paramètre-clef favorisant la rupture interfaciale. En effet, une étude à l’échelle microscopique sur la structure hétérogène du revêtement galvanique de la tôle a mis en évidence la présence de déformations localisées très importantes, qui semblent capable d’endommager l’interface collée. Le second objectif de la thèse a été de caractériser mécaniquement une interface tôle/adhésif. Deux méthodes complémentaires ont été proposées. La première consistait à caractériser l’interface dans des conditions « pures » de sollicitation, grâce à l’essai Arcan modifié. La seconde méthode a permis d’évaluer la capacité de l’interfaces à résister à un effet de bord, grâce à un essai de flexion trois points sur une éprouvette en coin.
These-2017-SPI-Sciences_de_l_ingenieur-LEGENDRE_Jean.pdf (499.41 Mo) Télécharger le fichier
tel-01711967 , version 1 (19-02-2018)
tel-01711967 , version 2 (19-02-2018)
  • HAL Id : tel-01711967 , version 2
Jean Legendre. Compréhension et caractérisation multi-échelle de la rupture interfaciale d'assemblages collés (colle crash - tôle galvanisée) pour l'automobile. Mécanique des matériaux [physics.class-ph]. Université de Bretagne occidentale - Brest, 2017. Français. ⟨NNT : 2017BRES0076⟩. ⟨tel-01711967v2⟩
691 Consultations
134 Téléchargements
