La taxation des étrangers non-résidents en France - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2016
Taxation of non-rensident aliens in France
Non-resident aliens represent a very specific legal category of taxpayers. Two conditions are necessarily met in order to tax these economic operators : a territoriality criterion relating to the location of their tax liability, it is the fiscal domicile; and then one of nationality. The definition of taxpayer is negative, as a matter of fact, it is a person who does not have French nationality, and who does not have tax domicile in France. The French legislature makes explicit references to non-resident foreigners in the Tax Code, the principle being the assimilation with the French non-residents. However, when there is a direct reference, it is to discriminate against national. This results in a difference in tax treatment most often contrary to EU and international standards which effectively act against any protectionist drift of the French legislator. Indeed, the principle of equality and its corollary, the principle of non-discrimination are fundamental principles of EU and international law, which are responsible for neutralizing the national tax systems which apply the criterion of nationality in the taxation of non-resident aliens in France. At last, breaking the principle of assimilation to national non-residents creates legal disputes that force the French legislator to align with the external legislation and which therefore tend to lead to an end to discrimination.
Les étrangers non-résidents représentent une catégorie juridique très particulière de contribuables. Deux conditions sont nécessairement réunies pour taxer ces opérateurs économiques : un critère de territorialité qui tient à la localisation de leur obligation fiscale, il s'agit du domicile fiscal ; et puis un critère de nationalité. La définition de ce contribuable est négative car il s'agit ainsi d'une personne qui n'a pas la nationalité française, et qui n'a pas son domicile fiscal en France. Le législateur ne fait que très rarement référence explicitement aux étrangers non-résidents dans le Code général des impôts, le principe étant l'assimilation avec les non-résidents français. Néanmoins, lorsqu'il y fait directement référence, c'est notamment pour le discriminer par rapport aux nationaux. Il en résulte une différence de traitement fiscal le plus souvent contraire aux normes communautaires et internationales lesquelles agissent efficacement contre toute dérive protectionniste du législateur français. En effet, le principe d'égalité et son corollaire le principe de non-discrimination constituent des principes fondamentaux du droit communautaire et international, lesquels se chargent de neutraliser les dispositifs fiscaux nationaux qui font application du critère de nationalité dans la taxation des étrangers non-résidents en France. En définitive, la rupture du principe d'assimilation envers les nationaux non-résidents crée des contentieux juridiques qui forcent l'Etat français à s'aligner sur la législation externe et qui tendent par conséquent à aboutir à la fin des discriminations.
2016__-_these_Florian_RAVAZ.pdf (1.92 Mo) Télécharger le fichier
tel-01713858 , version 1 (21-02-2018)
  • HAL Id : tel-01713858 , version 1
Florian Ravaz. La taxation des étrangers non-résidents en France. Droit. Université de Toulon, 2016. Français. ⟨NNT : 2016TOUL0103⟩. ⟨tel-01713858⟩
934 Consultations
6642 Téléchargements
