Revêtements polyuréthane-acrylate organiques/inorganiques superhydrophobes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2016
Superhydrophobic organic/inorganic coatings based on polyurethane acrylate matrices
This work deals with the development of organic/inorganic superhydrophobic UV-curable coatings manufactured through simple processes and from commercially available products. To achieve this goal, a hydrophilic polyurethane acrylate matrix (PUA) was used, in which several silicon-based compounds were introduced. The coatings were deposited using either bar- or spray-coating. The main objective was to structure the surface thanks to a multiscale roughness, while bringing a hydrophobic character, two properties needed to obtain a superhydrophobic coating (defined by a water contact angle superior to 150° and a water contact angle hysteresis inferior to 10°). The introduction of polyhedral oligomeric silsesquioxane molecules (POSS), presenting one acrylate and seven isobutyl ligands, brought a nanostructuration and a hydrophobic behavior to PUA coatings, even at low concentrations (≤ 1%wt.). However, the roughness obtained was not sufficient to bring the superhydrophobicity to the coatings.The introduction of fumed silica particles, functionalized by PDMS chains, established multiscale roughness and hydrophobic behavior at the surface, leading to superhydrophobic coatings. Moreover, the process had a high influence on physico-chemical modifications at the coatings’surface: superhydrophobicity is obtained for a relatively high concentration of fumed silica, 30%wt. and 60%wt. respectively for spray and bar-coating. In order to decrease these concentrations, we tried the combination of the two previous strategies: introduction of POSS molecules and fumed silica particles. This path raised the hydrophobic behavior of the coatings while keeping intact the roughness brought by fumed silica particles. This approach allowed to decrease the silica concentration needed to obtain superhydrophobicity for spray-coated coatings.
Ce travail de thèse a porté sur le développement de revêtements organiques/inorganiques photopolymérisables superhydrophobes à partir de procédés d’élaboration simples associés à des produits commerciaux largement diffusés. Pour cela, des revêtements à matrice polyuréthane acrylate (PUA), intrinsèquement hydrophiles, incluant différents composés à base de silicium ont été élaborés par enduction ou pulvérisation. L’objectif a été d’apporter en surface des revêtements une structuration multi-échelle et une chimie à caractère hydrophobe nécessaires pour atteindre la superhydrophobie, c’est-à-dire un angle de contact avec l’eau supérieur à 150° et une hystérésis de mouillage inférieure à 10°. L’introduction de molécules de polysilsesquioxane polyédrique (POSS), présentant un ligand acrylate et sept ligands isobutyle, a apporté une nanostructuration et un comportement hydrophobe aux revêtements PUA à des concentrations très faibles (≤ 1% en masse.). Cependant, la rugosité apportée se révèle trop faible et cette stratégie ne peut aboutir à la superhydrophobie des revêtements. L’introduction de particules de silice pyrogénée, modifiées en surface par des chaînes polydiméthylsiloxane, a permis d’établir une structuration multi-échelle et une chimie à caractère hydrophobe à la surface des revêtements PUA, leur conférant ainsi la superhydrophobie. De plus, le procédé d’élaboration a joué un rôle majeur sur les modifications physico-chimiques de surface des revêtements : la superhydrophobie est obtenue à une concentration relativement élevée de 30 et 60% en masse de silice pyrogénée respectivement par pulvérisation et enduction. Afin de diminuer ces concentrations, la combinaison des deux stratégies précédentes, c’est-à-dire l’introduction simultanée de POSS et de silice pyrogénée, a été considérée. Ceci a permis d’exacerber le caractère hydrophobe des revêtements tout en préservant la rugosité établie par la silice pyrogénée. Cette approche a conduit à la diminution de la concentration de silice nécessaire pour obtenir la superhydrophobie dans le cas des revêtements élaborés par pulvérisation.
these.pdf (39.98 Mo) Télécharger le fichier
tel-01715618 , version 1 (22-02-2018)
  • HAL Id : tel-01715618 , version 1
Aymeric Fourmentin. Revêtements polyuréthane-acrylate organiques/inorganiques superhydrophobes. Matériaux. Université de Lyon, 2016. Français. ⟨NNT : 2016LYSEI096⟩. ⟨tel-01715618⟩
715 Consultations
83 Téléchargements
