QTor : Une approche communautaire pour l'évaluation de requêtes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2016
QTor : Using communities to evaluate queries
This thesis addresses the problem of the organization of querying system on data streams under capacity constraints, such system being user-powered and based on the queries' similarity. Equivalence relations between queries allow to group the participants into communities. Those communities are then used as an abstraction to split the general organization problem into several easier and smaller subproblems. In order to stay language-independent, the organization is based on a simple and modular API, that rely on a query answering using views mechanism, well known in databases. Choice between the different rewritten queries is done using an adjustable cost model. Relations between communities are thus materialized by a spreading mechanism, a participant from one community joining the other(s) to contribute. This allows to avoid the capacities problem on the organization's abstract level, while efficiently taking care of it on the concrete one. Inside the communities, all the participants receive the common results they need using a spanning tree. The QTor approach, incrementally built, allows an efficient reduce of the processing and diffusion costs (processing cost being optimal in some cases, e.g. containment) with a reasonable latency, for a limited organization cost. Experiments have shown that the organization is flexible, regarding both the expressed queries and the participants' capacities. A demonstrator was built, allowing to both perform (automatic or interactive) simulations, and deploy the system over a real network, with a single.
Cette thèse porte sur la mise en place d'un système de requêtage sur des flux sous contraintes de capacités. Ce système est porté par ses utilisateurs-trices et basé sur les similitudes entre requêtes. Les relations d'équivalences entre les différentes requêtes permettent de réunir les participants au sein de communautés d'intérêt. Celles-ci forment alors une abstraction permettant de séparer le problème d'organisation du système en plusieurs sous-problèmes plus simples et de taille réduite. Afin de garantir une généricité vis-à-vis du langage, l'organisation repose sur une API simple et modulable. Nous avons ainsi recours au mécanisme de réécritures de requêtes utilisant des vues matérialisées, connu en bases de données, pour déterminer les relations possibles entre les communautés. Le choix entre ces différentes possibilités est ensuite effectué à l'aide d'un modèle de coût paramétrable. Les relations entre communautés sont concrétisées par un échange de ressources entre elles, un participant de l'une venant contribuer à l'autre. Cela permet de s'affranchir des limitations de capacités au niveau abstrait, tout en en tenant hautement compte pour la mise en relation effective des participants. Au sein des communautés, un arbre de diffusion permet à l'ensemble des participants de récupérer les résultats requis. L'approche, mise en œuvre de manière incrémentale, permet une réduction efficace des coûts de calcul et de diffusion (l'optimalité est atteinte, notamment, dans le cas de l'inclusion de requête) pour un coût d'organisation limité et une latence raisonnable. Les expérimentations réalisées ont montré une grande adaptabilité aux variations concernant les requêtes exprimées et les capacités des participants. Le démonstrateur mis en place peut être utilisé à la fois pour des simulations (automatiques ou interactives) et pour un déploiement réel, par une implémentation commune générique vis-à-vis du langage.
these.pdf (11.63 Mo) Télécharger le fichier
tel-01715623 , version 1 (22-02-2018)
  • HAL Id : tel-01715623 , version 1
Sébastien Dufromentel-Fougerit. QTor : Une approche communautaire pour l'évaluation de requêtes. Réseaux et télécommunications [cs.NI]. Université de Lyon, 2016. Français. ⟨NNT : 2016LYSEI132⟩. ⟨tel-01715623⟩
354 Consultations
159 Téléchargements
