Étude mathématique du problème de couplage océan-atmosphère incluant les échelles turbulentes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2018
Mathematical study of the air-sea coupling problem including turbulent scale effects
This thesis focuses on the numerical modelling of the air-sea coupling. Although they share some common features, these two physical environments are sufficiently dissimilar for their numerical treatment to be carried out by distinct models, each including their own specificities. The interactions between these two components are thus taken into account through coupling algorithms. Implementing such algorithms requires proper understanding of the oceanic and atmospheric modelling, most importantly in the vicinity of their common interface. Therefore a substantial part of this thesis dissects, analyzes and completes turbulent parameterization schemes, which are the numerical mechanisms, defined at a continuous level, through which the turbulent surface layer at the vicinity of the sea surface is treated. Two theoretically and numerically meaningful sources of errors in the numerical modelling of the air-sea interface have been isolated. The first source of error lies in the continuous formulation of the turbulent parameterizations, which are currently used in an incomplete manner, leading to mathematically irregular solution profiles. By carefully studying their theoretical bases, this thesis extends the parameterizations, allowing them to generate regular profiles within a standardized, bi-domain framework. Numerical investigations on physically relevant test cases show that including such an extension can result in considerable bias (of the order of 20%) in air-sea fluxes evaluations. From a theoretical perspective, carrying this extension leads to establishing simple criteria under which the air-sea coupling can be considered as coherent with respect to the two physical environments, and more importantly, to the turbulent parameterizations. The second source of error is algorithmic in essence: it is linked to the temporal discretization of the coupling mechanisms. Existing ad hoc methods do not guarantee perfect coherence of the air-sea fluxes from one model to the other. Global in time Schwarz algorithms, which have first been developed as domain decomposition methods, are good candidates for correcting these flaws, although their implementation to the air-sea context is a considerable challenge, given the complexity of this problem. Investigations on the numerical impact of such algorithms are carried out on simplified test cases. Thanks to the undertaken work on turbulent parameterizations, perspectives on the development of coupling algorithms are given, regarding both their coherence as per the aforementioned conditions, and the gradually increasing complexity of physical effects that are accounted for.
Cette thèse s'intéresse à la modélisation numérique du couplage entre l'océan et l'atmosphère. Bien que présentant un certain nombre de caractéristiques communes, ces deux milieux physiques sont suffisamment dissemblables pour être numériquement simulés par des modèles distincts, incluant chacun des spécificités propres. Par conséquent, leurs interactions sont prises en compte via des algorithmes de couplage multiphysique. La mise en place de tels algorithmes nécessite une bonne compréhension des modélisations des milieux océanique et atmosphérique, en particulier au voisinage de leur interface commune. C'est pourquoi une partie conséquente de la présente thèse dissèque, analyse et complète les paramétrisations turbulentes, qui sont des mécanismes numériques définis au niveau continu, traitant la couche limite turbulente au voisinage de la surface océanique. Les travaux entrepris ont permis d'identifier deux sources d'erreurs, théoriquement et numériquement significatives, dans la modélisation numérique standard de l'interface océan-atmosphère. La première source d'erreur se manifeste dans les formulations continues des paramétrisations turbulentes: celles-ci sont actuellement utilisées de manière incomplète, ce qui se traduit par le caractère mathématiquement irrégulier des solutions qu'elles génèrent. En revenant aux fondements de la théorie dont les paramétrisations découlent, la présente thèse étend leur domaine d'application, permettant de générer des profils de solution réguliers, dans un cadre théorique uniforme et bi-domaine. Les effets d'une telle extension sont numériquement évalués sur des cas tests physiquement réalistes: celle-ci peut mener à des biais considérables (de l'ordre de 20%) dans les flux échangés entre océan et atmosphère. D'un point de vue théorique, cette extension permet de définir des critères simples sous lesquels le couplage océan-atmosphère peut être considéré comme cohérent par rapport aux deux domaines physiques, et surtout aux paramétrisations turbulentes. La seconde source d'erreur est de nature algorithmique: elle concerne la discrétisation temporelle des mécanismes de couplage. Les méthodes actuelles, dites ad hoc, ne garantissent pas une complète cohérence des flux d'un modèle à l'autre. Les algorithmes de Schwarz "globaux en temps", issus de thématiques liées à la décomposition de domaine, constituent une piste intéressante pour traiter ces aspects. La mise en place de tels algorithmes sur des modèles physiquement réalistes représente un défi considérable. Leur impact numérique sur des cas tests simplifiés est évalué. L'étude préalable des paramétrisations turbulentes permet de donner des pistes quant au développement d'algorithmes de couplage, concernant à la fois la "cohérence du couplage" précédemment introduite, et l'incorporation graduelle d'effets physiques plus complexes.
these_final.pdf (6.16 Mo) Télécharger le fichier
tel-01717274 , version 1 (26-02-2018)
tel-01717274 , version 2 (15-03-2018)
tel-01717274 , version 3 (18-10-2018)
  • HAL Id : tel-01717274 , version 2
Charles Pelletier. Étude mathématique du problème de couplage océan-atmosphère incluant les échelles turbulentes. Equations aux dérivées partielles [math.AP]. Communauté Université Grenoble Alpes, 2018. Français. ⟨NNT : ⟩. ⟨tel-01717274v2⟩
865 Consultations
3049 Téléchargements
