Valorisation des analogies lexicales entre l'anglais et les langues romanes : étude prospective pour un dispositif plurilingue d'apprentissage du FLE dans le domaine de la santé - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2017
Emphasising lexical analogies between English and Romance languages : prospective study towards a plurilingual learning device of French for healthcare
This prospective lexicological investigation belongs to the field of L3 French didactics. The purpose is to elaborate a French-Italian-Portuguese-Spanish interlexicon out of the frequent adjectives, nouns and verbs of the healthcare scientific writings, and their analogue translation equivalents in French, Italian, Portuguese and Spanish. Two words are analogue if they have the same meaning and a similar form.Related concepts of analogy, similarity and identity are discussed, types of intralinguistic and cross-linguistic analogies reviewed, and the main analogies and differences between English, French and Romance languages detailed. Their many analogies are justified by Indo-European origins and mostly by intense language contacts. Once the importance of analogy in learning procedures has been highlighted, we show how this research and two types of didactic approaches connect together: intercomprehension, which develops comprehension skills in neighbor languages, and corpus approaches which enable to get a closer insight into scientific phraseology.The 2000 most frequent English lemmas were extracted from the ScienText English scientific corpus, their 2208 frequent acceptions explored from their combinatory profile and sorted out in two semantic categories: healthcare subject-specific vocabulary and science specific trans-disciplinary vocabulary. The English lemmas were translated into the four Romance languages, and similarity measurements were carried out with the longest common substring method.The interlexicon contains 47% of the frequent acceptions. Analogy is even higher by language pairs: English – French, 66%, English – Italian, 65%, English - Spanish, 63%, English – Portuguese, 58%. Consequently, this analogue vocabulary could form a transfer basis in learning activities of L3 French for health care providers, and L2 English seems to be a possible bridge language toward Romance languages. Plurilingual activities are built on concordances extracted from multilingual aligned corpora (EMEA, Europarl). Metalinguistic questions in English point out (morpho)syntactic features of French; the analogies between both languages are systematically enhanced, and in case of lexical opacity, those between English and the other Romance languages.
Cette étude lexicologique prospective s'inscrit dans la didactique des L3. L’objectif est d’élaborer un interlexique anglais-espagnol-français-italien-portugais composé des adjectifs, noms et verbes anglais fréquents dans les écrits scientifiques de la santé, et de leurs équivalents de traduction analogues en espagnol, français, italien et portugais. Deux mots sont analogues s’ils ont le même sens et une forme similaire.Les rapports entre les concepts d'analogie, de similarité et d'identité sont examinés, les types d'analogies intralinguistiques et interlinguistiques illustrés et les principales analogies et dissemblances entre l’anglais, le français et les langues romanes exposées. L'existence de celles-ci est justifiée par les origines indoeuropéennes et surtout d'intenses contacts de langues. Après avoir rappelé l’importance de l’analogie dans l’apprentissage, nous montrons le lien entre notre recherche et deux types d’approches didactiques des langues : l'intercompréhension, qui développe la compréhension de langues voisines, et les approches sur corpus qui permettent de mieux connaitre et faire connaitre la phraséologie scientifique.Les 2000 lemmes anglais les plus fréquents ont été extraits du corpus scientifique anglais de ScienText, leurs 2208 acceptions fréquentes délimitées sur la base du profil combinatoire et triées en deux catégories sémantiques : lexique de spécialité et lexique scientifique transdisciplinaire. Les lemmes anglais ont été traduits dans les quatre langues romanes, et la similarité mesurée en fonction de la sous-chaine maximale commune (SMC).L’interlexique contient 47 % des acceptions fréquentes. Par couples de langues, l’analogie est encore plus élevée : anglais – français, 66 %, anglais-italien, 65 %, anglais-espagnol, 63 %, anglais-portugais, 58 %. Ce lexique analogue pourrait donc servir comme base de transfert dans des activités de FLE L3 pour des professionnels de la santé, et l’anglais L2 semble être une passerelle possible vers les langues romanes. Des activités plurilingues sont construites sur des concordances extraites des corpus multilingues alignés EMEA et Europarl. Un questionnement métalinguistique en anglais sensibilise à des traits (morpho)syntaxiques du français ; les analogies des deux langues sont systématiquement mises en relief, et dans les cas d'opacité, celles des autres langues romanes avec l’anglais.
GILLES_2017_diffusion.pdf (3.13 Mo) Télécharger le fichier
tel-01719853 , version 1 (14-05-2018)
  • HAL Id : tel-01719853 , version 1
Fabrice Gilles. Valorisation des analogies lexicales entre l'anglais et les langues romanes : étude prospective pour un dispositif plurilingue d'apprentissage du FLE dans le domaine de la santé. Linguistique. Université Grenoble Alpes, 2017. Français. ⟨NNT : 2017GREAL011⟩. ⟨tel-01719853⟩
Collections
UGA STAR LIDILEM
545 Consultations
1494 Téléchargements
