Faecal indicator bacteria and organic carbon in the Red River, Viet Nam : measurements and modelling - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2016
Les bactéries indicatrices de contamination fécale et du carbone organique dans le Fleuve Rouge, Vietnam : observations et modélisation
In many developing countries, poor water quality poses a major threat to human health and the lack of access to clean drinking water and adequate sanitation continues is a major brake on development. The Red River is the second largest river in Vietnam and constitutes the main water source for the population of North Vietnam. This thesis presents the results from observations and modeling of both faecal indicator bacteria (FIB) and organic carbon (OC) in the Red River system, North Vietnam. The objective of this work was to measure FIB numbers and OC concentrations in this system and then to model these parameters in order to investigate scenarios for 2050 when population in the area is estimated to have doubled. The dataset was then modeled using the Seneque/Riverstrahler model in order to investigate the dynamics and seasonal distribution of FIB and OC in the Red River and its upstream tributaries. A scenario, based on the predicted changes in future demographics and land use in the Red River system for the 2050 horizon, showed only a limited increase of FIB numbers compared with the present situation. This was particularly the case in Hanoi even though the population is expected to triple by 2050. The OC inputs and the resulting heterotrophic respiration of this OC resulted in a system that was a strong CO2 source. The model results also reflected the importance of land use, discharge and the dominance of non-point sources over point sources for FIB and OC in the Red River. This thesis provides some new information on FIB in the Red River as well as providing a base for discussion with decision makers on the future management of wastewater in the Red River.
Dans de nombreux pays en développement, la qualité médiocre de l'eau constitue une menace majeure pour la santé humaine. Par ailleurs, le manque d'accès à l'eau potable et à l'assainissement sont un frein majeur au développement. La Fleuve Rouge est le deuxième plus grand fleuve au Vietnam et constitue la principale source d'eau pour la population du Nord-Vietnam. Cette thèse présente les résultats des observations et de la modélisation des bactéries indicatrices de la contamination fécales (BICF) et du carbone organique (CO) dans la Fleuve Rouge. Le modèle Seneque/RIVERSTRAHLER utilisant l’ensemble des données recueillies a permis d'étudier la dynamique et la répartition saisonnière des BICF et du CO dans la Fleuve Rouge et ses affluents. Un scénario, basé sur l’évolution démographique et les changements d’usage des terres prévus à l'horizon 2050, a montré une augmentation limitée des nombres des BICF par rapport à la situation actuelle. Ceci est particulièrement le cas pour la ville d’Hanoi même si la population devrait tripler d'ici 2050. Les apports en CO et la respiration hétérotrophe résultant du CO abouti à un système qui est une forte source en CO2 pour l’atmosphère. Les résultats du modèle reflètent également l'importance des différents usages des terres, le débit et la prédominance des sources diffuses relatifs aux sources ponctuelles sur les BIFC et CO dans le Fleuve Rouge. Cette thèse fournit de nouvelles informations sur les teneurs en BICF et CO dans la Fleuve Rouge ainsi qu’une base de discussion pour les décideurs sur la gestion future des eaux usées rejetés dans ce Fleuve.
2016PA066179.pdf (3.16 Mo) Télécharger le fichier
tel-01737872 , version 1 (20-03-2018)
  • HAL Id : tel-01737872 , version 1
Huong Thi Mai Nguyen. Faecal indicator bacteria and organic carbon in the Red River, Viet Nam : measurements and modelling. Biodiversity and Ecology. Université Pierre et Marie Curie - Paris VI; Vietnamese Academy of Science and Technology (Hanoi, Viet Nam), 2016. English. ⟨NNT : 2016PA066179⟩. ⟨tel-01737872⟩
309 Consultations
296 Téléchargements
