Impact d’un gain de fonction de Cxcr4 sur le développement et la compartimentalisation périphérique des lymphocytes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2013
Impact of a gain-of-Cxcr4-function in lymphocyte development and peripheral trafficking
Vincent Biajoux
  • Fonction : Auteur
  • PersonId : 771236
  • IdRef : 171364279
The WHIM Syndrome (WS) is a rare combined immuno-hematological disorder caused by inherited heterozygous autosomal dominant mutations in CXCR4, which result in most cases in the distal truncation of the receptor’s Carboxyl-terminal tail (C-Tail). Mutants of CXCR4 associated with WS display impaired desensitization and internalization of the receptor upon CXCL12 exposure, leading to enhanced migratory response. Because CXCR4 is expressed on leukocytes, we hypothesized that circulating pan-leukopenia could arise from altered CXCR4-mediated signalling that would skew tissue distribution and differentiation of leukocytes. This assumption was obviously difficult to address in patients. By generating a knock-in mouse strain (Cxcr4+/1013) that harbors a WS-linked gain-of-Cxcr4-function mutation, we establish that the C-tail domain in Cxcr4-mediated signalling is a pivotal regulator of lymphocyte development, peripheral trafficking and humoral immunity. The essential findings of our work, obtained by combining biochemical, bone marrow (BM)-mixed chimeras, in vivo labelling, adoptive co-transfers and functional approaches, are: 1) the C-tail truncating Cxcr41013 mutation caused differential signalling capacities depending on its heterozygous versus homozygous status and inhibited double-negative (DN) 2-to-DN3 and pro-B-to-pre-B developmental transitions during lymphopoiesis. In contrast, it had no effect on NK lymphopoiesis and granulopoiesis; 2) the resulting circulating B and T lymphopenia was due to hematopoietic cell-intrinsic defects and followed a mutated allele dose-dependent pattern; 3) impaired Cxcr41013 desensitization prevented the release of immature BM NK and B cells and mature lymph node (LN) B and T lymphocytes into the blood. Conversely, it forced homing and retention of mature recirculating B and T cells in the BM parenchyma; and 4) despite the absence of primary B-cell follicles in LNs, mutant mice produced efficient humoral responses upon immunization as illustrated by increased antigen-specific germinal center B cells and isotype-switched plasma cells. Collectively, our findings demonstrate that fine-tuning of Cxcr4 signal strength is required for optimal trafficking, egress and fitness of lymphocytes.
Le syndrome WHIM (SW) est un déficit immuno-hématologique rare causé principalement par des mutations autosomales dominantes du gène CXCR4 qui entrainent une troncation du domaine C-terminal (C-Ter) du récepteur. Les formes mutantes de CXCR4 associées au SW génèrent des altérations de la désensibilisation et de l’internalisation du récepteur en réponse à CXCL12, qui se traduisent par une hypersensibilité à l’action chimiotactique du ligand. CXCR4 est un récepteur de chimiokine exprimé sur les leucocytes dont le rôle dans l’hématopoïèse et le trafic leucocytaire à l’état basal suggère que la lympho-neutropénie des patients atteints du SW est due à des défauts de production et/ou de domiciliation périphérique des leucocytes causés par le gain de fonction de CXCR4. Néanmoins, la validation de cette hypothèse est difficile chez les patients. En générant une souche de souris (Cxcr4+/1013), porteuse d’une mutation rapportée chez une famille de patients par une stratégie de knock-in, nous avons mis en évidence le rôle du domaine C-Ter de Cxcr4 dans le développement, la domiciliation périphérique des lymphocytes et l’immunité adaptative à médiation humorale.Les principaux résultats issus de notre travail, obtenus en combinant des approches biochimiques, fonctionnelles, de reconstitution de l’hématopoïèse par compétition, de transferts adoptifs et d’injection d’anticorps anti-CD45 in vivo, sont : 1) La mutation Cxcr41013 tronquant le domaine C-Ter se comporte différemment en terme de signalisation, selon qu’elle soit présente à l’état hétérozygote ou homozygote, et perturbe respectivement les transitions double-négatif (DN) 2-DN3 et proB-preB de la lymphopoïèse dans le thymus et la moelle osseuse (MO). Au contraire, elle ne génère pas d’effets sur le développement des cellules NK et la myélopoïèse ; 2) La lymphopénie qui touche les lymphocytes B (LB) et T (LT) est un processus intrinsèque aux cellules porteuses de la mutation Cxcr41013 et suit un modèle allèle-dose-dépendant ; 3) Le défaut de désensibilisation de Cxcr41013 empêche le relargage des lymphocytes NK et B immatures de la MO et celui des LB et LT matures des ganglions lymphatiques dans le sang. A l’inverse, le gain de fonction exacerbe la migration des LB recirculants et LT matures et leur rétention dans le parenchyme médullaire ; et 4) malgré l’absence de follicules primaires dans les ganglions lymphatiques, les souris mutantes sont capables de mettre en place une réponse immunitaire humorale efficace et spécifique d’un antigène T-dépendant, comme en témoigne l’augmentation des LB du centre germinatif et des plasmocytes ayant effectué une commutation isotypique. En conclusion, nous démontrons que la signalisation fine médiée par Cxcr4 est nécessaire pour le développement, la compartimentalisation périphérique et la fonction des lymphocytes.
VA_BIAJOUX_VINCENT_30092013.pdf (36 Mo) Télécharger le fichier
tel-01740411 , version 1 (22-03-2018)
tel-01740411 , version 2 (19-07-2018)
  • HAL Id : tel-01740411 , version 2
Vincent Biajoux. Impact d’un gain de fonction de Cxcr4 sur le développement et la compartimentalisation périphérique des lymphocytes. Sciences agricoles. Université Paris Sud - Paris XI, 2013. Français. ⟨NNT : 2013PA114825⟩. ⟨tel-01740411v2⟩
246 Consultations
27 Téléchargements
