Synthesis, characterization and spectroscopy of Co and Co (core) / (shell) CoO self-assembled nanoparticles
Synthèse, caractérisation et spectroscopie de nanoparticules de Co et (coeur) Co / (coquille) CoO auto-organisées
One of the present challenges in the field of nanomaterial chemistry is to develop strategies aimed at controlling not only the growth of metal nanoparticles (NPs), but also their long-distance organization. Another important goal is controlling the oxidation of NPs and especially the formation of complex oxides having a core (metal) @ shell (metal oxide) architecture. In this context, by revisiting micellar synthesis, a strategy based on the modification of solvent-controlled ligand-ligand interactions was established, following the modeling of the Hansen solubility, of controlling the size of cobalt NPs (3.8 nm to 9.1 nm). Dodecanoic acid NPs passives and protects from oxidation and coalescence (TEM & SAXS control). Hexagonal lattice monolayers and face-centered 3D fcc superlattices were obtained. Using two oxidation strategies combined with annealing, dry and in solution, core / shell NPs: Co (ferro) @CoO (antiferromagnetic)/ were prepared with a polycrystalline metal core cfc or monocrystalline hcp. The preliminary study of the magnetic properties (SQUID) shows that the Co / CoO interface favors a moderate ferromagnetic / antiferromagnetic exchange interaction. Raman spectroscopy, a non-invasive method, under different laser excitations allows the simultaneous analysis of the metal particle (phase control and measurement of diameters from Lamb's modes), coating agent and its interaction with the NP and the possible oxide shells (CoO/CoOH, CO3O4) as well as the dynamics of the dodecanaote chains. Infrared analysis indicates hydroxylation of the unoxidized NPs. The vibrational techniques appear well adapted to the multi-scale control of NPs assemblies and supracrystals.
L’un des enjeux actuels dans le domaine de la chimie des nanomatériaux est de développer des stratégies visant à contrôler la synthèse, l’organisation et la réactivité de nanoparticules (NPs) métalliques, y compris sous forme cœur (métal)@coquille (oxyde(s)). Dans ce contexte, en revisitant la synthèse par voie micellaire, a été établi une stratégie basée sur la modification des interactions ligand-ligand contrôlées par le solvant, suivant la modélisation de la solubilité de Hansen, afin de contrôler de la taille des NPs de cobalt entre 3,8 nm et 9,1 nm (mesure MET). De l’acide dodécanoïque passive les NPs et protège de l’oxydation et de la coalescence. Des monocouches en réseau hexagonal et des supercristaux cfc ont été obtenus. En utilisant deux méthodes d’oxydation combinées à des recuits, par voie sèche et en solution, des NPs coeur/coquille [Co(ferro)@CoO(antiferromagnétique)] ont été préparées avec un cœur métallique polycristallin cfc ou monocristallin hcp. L’étude préliminaire des propriétés magnétiques (mesures SQUID) montre que l’interface Co/CoO favorise une interaction d’échange ferromagnétique/antiferromagnétique faible. La spectroscopie Raman, méthode non-invasive, sous différentes excitations laser permet d’analyser simultanément la particule métallique (contrôle de la phase et mesure des diamètres à partir des modes de Lambs), l’agent passivant et les éventuelles coquilles d’oxyde (CoO/CoOH, Co3O4) ainsi que la dynamique des chaines dodécanoates. L’analyse infrarouge indique une hydroxylation des NPs non oxydées. Les techniques vibrationnelles apparaissent bien adaptées au contrôle multi-échelle des assemblées et supracristaux de NPs.
