Dynamique des flux d'investissement en OPCVM sur le marché français : stratégies du promoteur et conflits d'intérêts avec l'investisseur - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2012
Dynamics of mutual funds flows in the French UCITS market : strategies of promoter and conflicts of interest with investor
This thesis aims to explain the convex relationship between mutual funds flows and their performance, related to the strategies of funds promoters. Our theory is the following: because the mutual fund promoter's profit is dependent on the amount of assets under management, they have a strong incitation to induce this convexity. Using Hotelling models and switching cost theory, we have identified two strategies available to promoters: the "supply policy", which consists in building and maintaining a strong customer relationship with investors and "informational policy", which aims to feed investors' beliefs according to which the promoters give more performing funds than competitors. Two empirical studies, using EUROPERFORMANCE database include 8161 French UCITS from 1998 to 2002, are proposed. We conduct multilevel models that explicitly take account of the common variance shared by UCITS that are provided through the same promoter. The main results point out that, after taking into account the non-independence of observations, the convexity of the flow-performance relationship is more or less pronounced depending on the promoters' efficiency to use their strategies. We also show that strategies adopted by promoters vary according to financial market conjuncture: the growth period is marked by a "prime to uncertainty" where the promoters reputation, which enables them to enjoy "spillover effect" is the most effective strategy to improve market share. In period of crisis, it is the ability of promoters to internalize flows and organize their internal market with an efficient "supply policy" that explains their ability to maximize market share. Finally, the reputation of the promoters has a direct positive effect on flows and increases their sensitivity to the performance of UCITS. The search for "spillover effect", which is in conflict of interests with investors, is the dominant strategy adopted by the promoters of French UCITS.
Cette thèse vise à expliquer la relation convexe entre les flux d'investissement dans les fonds et leur performance, à partir de la stratégie des promoteurs d'OPCVM en France. Partant du constat que le profit des promoteurs est dépendant de la quantité d'actifs sous gestion, ces derniers seraient fortement incités à mener des stratégies qui entrent en conflit avec les intérêts de l'investisseur dans le but d'induire la convexité de la relation flux-performance. Mobilisant les théories issues des modèles d'Hotelling avec biens différenciés, et les théories des coûts de changement, nous avons mis en évidence deux stratégies à disposition des promoteurs : la « politique de l'offre », qui est destinée à forger et maintenir une relation clientèle forte avec l'investisseur et la « politique informationnelle », qui vise à nourrir les croyances des investisseurs selon lesquelles leurs promoteurs d'OPCVM offrent les titres les plus performants au regard de la concurrence. Deux études empiriques, mobilisant la base de données EUROPERFORMANCE qui recense 8 161 OPCVM commercialisés en France de 1998 à 2002, sont proposées. Les estimations sont menées à l'aide des modèles multiniveaux, qui tiennent explicitement compte de la variance commune partagée par les OPCVM qui sont distribués par un même promoteur. Les principaux résultats obtenus montrent que, une fois prise en compte la non-indépendance des observations, la convexité de la relation flux-performance est plus ou moins marquée selon l'efficacité des promoteurs à mener les politiques de l'offre et les politiques informationnelles. Nous montrons également que les stratégies adoptées par les promoteurs varient selon la conjoncture boursière : la période de croissance est marquée par une « prime à l'incertitude » où la réputation des promoteurs d'OPCVM, qui leur permet de bénéficier d'effet spillover, est la stratégie la plus efficace pour obtenir des parts de marché. En période de crise, c'est la capacité des promoteurs à internaliser les flux de capitaux et organiser leur marché interne d'OPCVM grâce à une politique de l'offre efficace, qui explique le mieux leur capacité à maximiser les parts de marché. Enfin, la réputation des promoteurs a bien un effet positif direct sur les flux et accroît significativement leur sensibilité à la performance des OPCVM. La recherche d'effet spillover, qui entre directement en conflit avec les intérêts des investisseurs, est bien la stratégie dominante adoptée par les promoteurs d'OPCVM.
DDOC_T_2012_0064_KHIM.pdf (4.93 Mo) Télécharger le fichier
tel-01749188 , version 1 (29-03-2018)
  • HAL Id : tel-01749188 , version 1
Veasna Khim. Dynamique des flux d'investissement en OPCVM sur le marché français : stratégies du promoteur et conflits d'intérêts avec l'investisseur. Gestion et management. Université de Lorraine, 2012. Français. ⟨NNT : 2012LORR0064⟩. ⟨tel-01749188⟩
230 Consultations
646 Téléchargements
