Modélisation de populations neuronales pour l'intégration visuo-motrice : dynamiques et décisions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2012
Modeling of neural populations for visuo-motor integration: Dynamics and decisions
Within the context of enaction and a global approach to perception, we focused on the characteristics of neural computation necessary to understand the relationship between structures in the brain and their functions. We first considered computational problems related to the discretization of differential equations that govern the studied systems and the synchronous and asynchronous evaluation schemes. Then, we investigated a basic functional level : the transformation of spatial sensory representations into temporal motor actions within the visual-motor system. We focused on the visual flow from the retina to the superior colliculus to propose a minimalist model of automatic encoding of saccades to visual targets. This model, based on simple local rules (CNFT and logarithmic projection) in a homogeneous population and using a sequential processing, reproduces and explains several results of biological experiments. It is then considered as a robust and efficient basic model. Finally, we investigated a more general functional level by proposing a computational model of the basal ganglia motor loop. This model integrates sensory, motor and motivational flows to perform a global decision based on local assessments. We implemented an adaptive process for action selection and context encoding through an innovative mechanism that allows to form the basic circuit for other cortico-basal loops. This mechanism allows to create internal representations according to the enactive approach that opposes the computer metaphor of the brain. Both models have interesting dynamics to study from whether a biological point of view or a computational numerical one
Dans le contexte de l'énaction et dans une approche globale de la perception, nous nous sommes intéressés à étudier calcul neuronal permettant de comprendre les relations entre les structures dans le cerveau et leurs fonctions. Nous avons d'abord examiné les problèmes calculatoires liés à la discrétisation des équations différentielles qui régissent les systèmes étudiés et aux schémas d'évaluation synchrones et asynchrones. Nous nous sommes, ensuite, intéressés à un niveau fonctionnel élémentaire: la transformation de représentations sensorielles spatiales en actes moteurs temporels dans le cadre du système visuo-moteur. Nous avons proposé un modèle minimaliste d'encodage automatique des cibles visuelles de saccades qui se concentre sur le le flux visuel de la rétine vers le colliculus supérieur. Ce modèle, basé sur sur des règles locales simples au sein d'une population homogène, permet de reproduire et d'expliquer plusieurs résultats d'expériences biologiques ce qui en fait un modèle de base efficace et robuste. Enfin, nous avons abordé un niveau fonctionnel plus global en proposant un modèle de la boucle motrice des ganglions de la base permettant d'intégrer des flux sensoriels, moteurs et motivationnels en vue d'une décision globale reposant sur des évaluations locales. Ce modèle met en exergue un processus adaptatif de sélection de l'action et d'encodage de contexte via des mécanismes originaux lui permettant en particulier de constituer la brique de base pour les autres boucles cortico-basales. Les deux modèles présentent des dynamiques intéressantes à étudier que ce soit d'un point de vue biologique ou d'un point de vue informatique computationnel
DDOC_T_2012_0105_TAOUALI.pdf (3.73 Mo) Télécharger le fichier
tel-01749297 , version 2 (08-11-2012)
tel-01749297 , version 1 (29-03-2018)
  • HAL Id : tel-01749297 , version 1
Wahiba Taouali. Modélisation de populations neuronales pour l'intégration visuo-motrice : dynamiques et décisions. Autre [cs.OH]. Université de Lorraine, 2012. Français. ⟨NNT : 2012LORR0105⟩. ⟨tel-01749297v1⟩
381 Consultations
1562 Téléchargements
