Theses
Accessibility of Referents in Discourse Semantics
Abstract : This thesis has its roots in the standard Montagovian and dynamic semantic tradition. The subject is conditions under which a noun phrase may act as antecedent of a particular anaphoric expression. The work thesis deals with the accessibility of discourse referents using a formal system of dynamic semantics. The framework used is the one proposed by De Groote, Type Theoretic Dynamic Logic (TTDL) because it follows the Montagovian tradition and only makes use of standard mathematical and logical tools which allows to maintain compositionnality. We extend the coverage of TTDL to cases which are naturally problematic for classical dynamic semantic theories. In particularly, this thesis aims to extend TTDL's coverage of the accessibility of referents to two exceptions of classical dynamic theories, namely anaphora under double negation and modality. An adaptation is defined for each case and finally, an integration of various solutions is proposed, which shows the flexibility of TTDL
Complete list of metadatas
https://hal.univ-lorraine.fr/tel-01750993
Contributor : Thèses Ul <>
Submitted on : Thursday, March 29, 2018 - 1:00:57 PM
Last modification on : Tuesday, May 22, 2018 - 3:32:21 PM
File
DDOC_T_2014_0138_QIAN.pdf
Identifiers
  • HAL Id : tel-01750993, version 1
Citation
Sai Qian. Accessibility of Referents in Discourse Semantics. Other [cs.OH]. Université de Lorraine, 2014. English. ⟨NNT : 2014LORR0138⟩. ⟨tel-01750993v1⟩
Share
Metrics
Record views
38
Files downloads
9
