Towards quantum applications based on photonic entanglement
Vers les technologies quantiques basées sur l’intrication photonique
The aim of this thesis was to develop photonic entanglement sources and study their implementation in the general field of quantum information technologies. To this end, a novel fully wave-guided, high performance photonic entanglement source is presented, able to generate hyper-entangled states in the observables of polarization and energy-time by means of a nonlinear Sagnac loop. The waveguide-based design makes it flexible, reliable, and adaptable to a wide spectral range, paving the way towards compact photonic entanglement generators, compatible with fiber-based communication systems and networks. This has been underlined by generating and distributing hyperentanglement in 5x2 dense wavelength division multiplexed channel telecom pairs, simultaneously, towards higher bit rates. The quality of the generated entanglement has been qualified by violating the Bell inequalities in a 16-dimension Hilbert space. Moreover, to adapt the wavelength of the entangled telecom photon pairs to the absorption wavelength of current quantum memory systems, a coherent wavelength converter is demonstrated. Furthermore, within the framework of quantum metrology, a new concept for a high-precision chromatic dispersion (CD) measurement in standard single mode fibers is introduced and demonstrated. In this demonstration, due to conceptual advantages enabled by quantum optics, an unprecedented 2.6 times higher accuracy on CD measurements is shown, compared to state-of-the-art techniques. In the same context, a new protocol for measuring two-photon phase shifts is performed using single photon detection only, promising scalable and potential real device applications with limited resources and simplified detection schemes. Finally, any potential application of quantum optics will be realized using small-scale devices. In this framework, an integrated on-chip heralded path entanglement generator is demonstrated, and shown to be adaptable to logic gate operations.
Le but de cette thèse est de développer des sources d’intrication photonique en vue d'applications en sciences information quantique. Dans ce contexte, nous présentons une source très performante et entièrement guidée permettant, au moyen d'une boucle de Sagnac, la génération d'états hyper-intriqués en polarisation et en énergie-temps. La configuration guidée rend le dispositif versatile, efficace et compatible avec une large bande spectrale, répondant ainsi au besoin des systèmes et réseaux de communication fibrés. À cette fin, nous avons distribué simultanément dans différents canaux télécoms des paires de photons hyper-intriqués au moyen de multiplexeurs en longueur d'onde à 5 canaux (DWDM), augmentant de fait le débit. La qualité de l'intrication est validée par la violation d'une inégalité de Bell étendue à un espace de Hilbert à 16 dimensions. Afin de pouvoir interfacer des photons aux longueurs d'ondes des télécommunications avec les bandes d'absorption des mémoires quantiques situées dans le visible, nous avons également développé une interface cohérente en longueur d'ondes. Un nouveau dispositif de métrologie quantique permettant la mesure avec une précision inégalée des effets de la dispersion chromatique dans les fibres optiques standards est également proposé. Notre approche "quantique" améliore la précision par un facteur 2.6 par rapport aux méthodes de mesures conventionnelles. Dans ce même contexte, nous avons aussi implémenté un nouveau protocole de métrologie de la phase de deux photons en ne détectant uniquement qu'un seul photon. Cette réalisation ouvre la voie à des applications potentielles simples s'appuyant sur peu de ressources au niveau de la détection. Finalement, dans la perspective de la miniaturisation de dispositifs quantiques, nous avons démontré un générateur d'intrication annoncée intégré sur puce qui trouve des applications en calcul et métrologie quantique.
