Personnalisation morpho-mécanique de la voûte crânienne humaine à différentes vitesses de sollicitations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2017
Morpho-mechanical personalization of the human skull with various strain rates
Today, the digital models are usually used in the world of research, but also in industry, health, finance, etc.… The quality of the results will always be connected to the accuracy with which the engineer is able of formalizing the physical phenomena. More specifically in the biomechanical modelling, working with a high number of parameters, making very complicated the standardization of the models. This thesis has an approach of improvement in the quality of the digital models of the human skull through several studies having for aim the analysis of the morphological parameters of the skull and their use for the personalization of a morpho-mechanical model.The method of scan by micro-tomography was used to scan more than 360 samples taken from 10 skulls, and then mechanical tests of compression in quasi-statics and dynamics were led on a part of these samples. The results we obtained allowed us to develop a card of evolution of a number of morphological parameters of the skull based on a polynomial model. A statistical comparative study allowed to highlight the existing links between the morphology and the mechanical behaviour of these samples. Finally, the connection of these two studies allowed to propose a customizable morpho-mechanical model, and to validate it for various finite elements simulations on bones samples and on complete human skull.
Aujourd’hui, les modèles numériques sont couramment utilisés dans le monde de la recherche, mais aussi de l’industrie, de la santé, de la finance, etc… La qualité du résultat sera toujours liée à la finesse et à la précision avec laquelle l’ingénieur est capable de formaliser les phénomènes physiques rencontrés. Dans le cadre plus spécifique de la modélisation biomécanique, énormément de paramètres rentrent en compte, rendant très compliquée la standardisation des modèles. Cette thèse s’inscrit donc dans une démarche d’amélioration de la qualité des modèles numériques du crâne humain au travers de plusieurs études ayant pour objectif d’analyser les paramètres morphologiques du crâne et de les utiliser pour la personnalisation d’un modèle morpho-mécanique. La méthode de scan par micro-tomographie a été utilisée pour scanner plus de 360 échantillons prélevé sur 10 crânes, puis des essais mécaniques de compression quasi-statiques et dynamiques ont été menés sur une partie de ces échantillons. Les résultats obtenus ont permis de développer une carte d’évolution d’un certain nombre de paramètres morphologiques du crane basés sur un modèle polynomiale. Une étude comparative statistique a permis de mettre en évidences les liens existants entre la morphologie et le comportement mécanique de ces échantillons. Au final, la liaison de ces deux études a permis de proposer un modèle morpho-mécanique personnalisable, puis de le valider pour différentes simulations éléments finis sur des échantillons osseux et sur une voute crânienne complète.
Karkar_Manaf2.pdf (5.47 Mo) Télécharger le fichier
tel-01771786 , version 1 (19-04-2018)
  • HAL Id : tel-01771786 , version 1
Manaf Karkar. Personnalisation morpho-mécanique de la voûte crânienne humaine à différentes vitesses de sollicitations. Biomécanique [physics.med-ph]. Université de Valenciennes et du Hainaut-Cambresis, 2017. Français. ⟨NNT : 2017VALE0035⟩. ⟨tel-01771786⟩
174 Consultations
768 Téléchargements
