Implication de la protéine de biogenèse des ribosomes Rsl24d1 dans l'homéostasie de cellules souches embryonnaires murines - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2018
Role of the ribosome biogenesis protein Rsl24d1 in mouse embryonic stem cells
Embryonic stem cells (ESC) possess clonogenic and pluripotency abilities i.e. they are able to self-renew indefinitely in the same developpemental state and to differentiate in all the cell types composing embryonic and adult tissues. ESC homeostasis is coordinated by complex networks which are regulated at different levels of gene expression regulation, including epigenetic, transcriptional and post-transcriptional levels. Furthermore, emerging evidences point out that the translational machinery, ribosomes, are directly implicated in the control of adult and embryonic stem cell homeostasis in different model organisms. Along this line, we have identified Rsl24d1, a ribosomal associated protein (RaP), which is strongly expressed in naïve murine ESCs compared to their differentiated progenies. We demonstrated that Rsl24d1 actively contributes to ESC homeostasis and its expression is essential for ESC proliferation and clonogenic capacities. Finally, we have also demonstrated that Rsl24d1, like Rlp24 its yeast ortholog, is associated to pre-ribosomes in ESCs from the nucleus to the cytoplasm and is required for the biogenesis of the large ribosomal subunit
Le contrôle de l'expression des programmes géniques orchestrant le développement précoce et l'homéostasie des cellules souches fait l'objet de recherches intenses. En effet, les cellules souches embryonnaires (CSE) sont caractérisées par des propriétés comme leur clonogénicité (la capacité à proliférer dans le même état indifférencié) et leur pluripotence (la capacité à se différencier et à former les tissus embryonnaires et adultes). Au niveau moléculaire, l'identité des CSE est orchestrée par le contrôle de l'expression génique aux niveaux épigénétique, transcriptionnel, post- transcriptionnel et traductionnel en réponse à l'activation de voies de signalisation spécifiques. Dans ce contexte, des données récentes suggèrent un rôle de la machinerie traductionnelle les ribosomes et de la régulation de leur biogenèse, dans le maintien de l'homéostasie de cellules souches de différentes espèces. À partir de l'analyse de données transcriptomiques à haut débit (RNAseq), mon équipe d'accueil a ainsi identifié un ensemble de protéines associées aux ribosomes (PaR) significativement enrichies dans les cellules souches embryonnaires murines (CSEm) en comparaison à des lignées cellulaires murines différenciées et à des tissus. Parmi ces candidats, mes travaux de thèse ont consisté à la caractérisation d'une PaR particulièrement enrichie : Rsl24d1. Rsl24d1 est une protéine de biogenèse des ribosomes décrites exclusivement chez la levure. Son profil d'expression dans différentes lignées de CSEm suggère une fonction spécifique: enrichissement au niveau transcriptionnel et protéique dans les CSE à l'état de pluripotence naïf et diminution importante au cours de la différenciation. En effet, des approches de perte d'expression de Rsl24d1 m'ont permis d'établir l'importance de cette PaR dans l'homéostasie des CSEm. Rsl24d1 contribue au maintien de la prolifération cellulaire des CSE, de leur clonogénicité et plus modérément à leur pluripotence. Rsl24d1 semble être une protéine majoritairement nucléaire mais également associée aux sous- unités 60S libres des ribosomes cytoplasmiques. D'autre part, la perte d'expression de Rsl24d1 affecte spécifiquement la biogenèse des particules ribosomiques 60S. Ainsi, comme chez la levure, dans les CSEm, Rsl24d1 est un facteur navette orchestrant la maturation des particules ribosomiques pré-60S. Par ailleurs, Rsl24d1 semble permettre le maintien d'un taux de synthèse protéique élevé permettant notamment le renouvellement des protéines ayant une demi-vie courte parmi lesquels on recense des facteurs de transcription de la pluripotence comme Oct4 (Oct3/4), Nanog et Esrrb. Mes travaux de thèse ont donc permis d'identifier et de caractériser un facteur de biogenèse de la sous-unité 60S, Rsl24d1, impliqué dans l'homéostasie des CSEm
TH2018BruelleMarionVExpurgee.pdf (2 Mo) Télécharger le fichier
tel-01775053 , version 1 (24-04-2018)
  • HAL Id : tel-01775053 , version 1
Marion Bruelle. Implication de la protéine de biogenèse des ribosomes Rsl24d1 dans l'homéostasie de cellules souches embryonnaires murines. Biologie cellulaire. Université de Lyon, 2018. Français. ⟨NNT : 2018LYSE1015⟩. ⟨tel-01775053⟩
254 Consultations
760 Téléchargements
