Films nanocomposites plasmoniques auto-assemblés - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2017
Self-Assembled Plasmonic Nanocomposite Films
Metamaterials are artificial materials, made from the assembly of nano-resonators, which can interact with incoming waves and get properties unknown for homogeneous materials. In order to fabricate metamaterials with an effect over visible light, a precise control over the organization at the nanoscale is required. The goal of this project was then the use of bottom-up approaches to achieve the anisotropic organization of gold nanoparticles (AuNPs), which are resonators due to their plasmonic properties, into a poly(styrene)-b-poly(vinylpyridine) block copolymer film, with a nanostructuration in arrays of PVP cylindrical domains perpendicular to the substrate.During this work, we investigated routes for the fabrication of copolymer films containing ordered gold nanoparticles in a hexagonal cylindrical phase. The orientation of the cylinders normal to the substrate was obtained by casting the copolymer with a neutral solvent whose composition was found dependent on the volumic fraction of PVP in the copolymer. The film structure with and without AuNPs was characterized by microscopy and Grazing-Incidence Small-Angle X-rays Scattering (GISAXS). Several incorporation methods for the insertion of AuNPs were studied, either by the in situ synthesis of the nanoparticles in solution before casting or directly into the ordered film; or by incorporating pre-formed AuNPs in the copolymer solution or in the film as-cast. In the case of the in situ synthesis, the AuNPs were formed by chemical or physical (sonication, radiolysis) reduction of a gold salt in the copolymer. The incorporation of pre-formed AuNPs was, achieved thanks to the functionalization of the AuNPs or by a treatment of the copolymer film in order to facilitate the insertion of the AuNPs.
Les métamatériaux sont des matériaux artificiels, formés par l’assemblage de nano-résonateurs, qui ont la capacité d’interagir avec les ondes qui les traversent et de conférer des propriétés inaccessibles aux matériaux homogènes. Afin de fabriquer de tels métamatériaux agissant dans le domaine du visible, un contrôle précis de l’organisation des résonateurs à l’échelle nanométrique est requis. Dans ce projet nous avons donc élaboré des voies de fabrication de type bottom-up, en organisant de façon anisotrope des nanoparticules d’or (AuNPs), qui sont des résonateurs du fait de leurs propriétés plasmoniques, dans un film de copolymères à blocs poly(styrène)-b-poly(vinylpyridine) (PS-b-PVP) nano-structuré en rangées de cylindres de PVP perpendiculaires au substrat.Au cours de ce projet, nous avons élaboré des routes de formulation permettant de produire des films de phase cylindrique hexagonale de copolymères alignés contenant des nanoparticules d’or. L’orientation des cylindres perpendiculaires au substrat a été obtenue en déposant le copolymère grâce à un solvant neutre dont la composition dépend de la fraction volumique en PVP du copolymère. La structure des films avec et sans nanoparticules a été caractérisée par microscopie et diffusion des rayons X en incidence rasante (GISAXS). Plusieurs méthodes d’incorporation des nanoparticules d’or ont été étudiées, soit en synthétisant les nanoparticules au sein du copolymère, en solution avant dépôt ou directement dans le film organisé ; soit en incorporant des nanoparticules pré-formées, en solution de copolymère ou dans le film déposé. Dans le cas de la synthèse in situ, nous avons formé les AuNPs par réduction chimique ou physique (sonication, radiolyse) d’un sel d’or dans le copolymère. L’incorporation des AuNPs pré-formées, elle, a été réalisée grâce à la fonctionnalisation des AuNPs ou par un traitement du film de copolymère afin de faciliter l’insertion des AuNPs.
AUBRIT_FLORIAN_2017.pdf (58.18 Mo) Télécharger le fichier
tel-01778007 , version 1 (25-04-2018)
  • HAL Id : tel-01778007 , version 1
Florian Aubrit. Films nanocomposites plasmoniques auto-assemblés. Autre. Université de Bordeaux, 2017. Français. ⟨NNT : 2017BORD0727⟩. ⟨tel-01778007⟩
203 Consultations
43 Téléchargements
