Développement de méthodes de diagnostic rapide d'erreurs innées du métabolisme associées à des troubles neurologiques - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2017
Rapid diagnostic method development of inborn errors of metabolism associated to some neurological disorders
Inborn errors of metabolism are inherited diseases that can alter the synthesis and transport of neurotransmitters. The diagnosis of these conditions is currently based on the chromatographic analysis of a biological fluid [plasma, urine, cerebrospinal fluid (CSF)]. The aim of this thesis was to develop simple and rapid methods for the diagnosis of neurotransmitter disorders. Firstly, we developed and validated the simultaneous determination of dopamine, serotonin, and tetrahydrobiopterin (BH4) metabolites by ultrahigh pressure liquid chromatography (UHPLC) coupled to sequential electrochemical and fluorimetric detection. This method was applied to the analysis of 1372 CSF samples, thus establishing the frequent ranges of the French population. In order to transpose the previous method into UHPLC coupled to mass spectrometry (MS), we studied the mechanisms of auto- and electro- oxidation of BH4, by Differential Ion Mobility coupled to high resolution MS (FTICR) in conjunction with Infra-Red photo-dissociation. This work allowed us to isolate and characterize qBH2, the transient reaction intermediate of BH4, involved in the mechanism of action of the latter. The proposed UHPLC-MS/MS method also allows the simultaneous determination of 5-methyltetrahydrofolate.
Les erreurs innées du métabolisme sont des maladies héréditaires pouvant affecter, entre autres, la synthèse et le transport des neurotransmetteurs. Le diagnostic de ces pathologies repose essentiellement sur l’analyse par chromatographie d’un fluide biologique [plasma, urine, liquide céphalorachidien (LCR)]. L’objectif de cette thèse était de développer des méthodes simples et rapides pour le diagnostique des troubles de la neurotransmission. Dans un premier temps, nous avons développé et validé le dosage simultané, en moins de 10 minutes, des métabolites de la dopamine, de la sérotonine et de la tétrahydrobioptérine (BH4) par chromatographie liquide ultra-haute pression (UHPLC) couplée à une détection séquentielle électrochimique et fluorimétrique. Cette méthode a été appliquée à l’analyse de 1372 échantillons de LCR, permettant ainsi d’établir les valeurs fréquentes de la population française. Afin de transposer la méthode précédente en UHPLC couplée à la spectrométrie de masse (MS), nous avons étudié les mécanismes d’auto- et d’électro- oxydation de la BH4, par mobilité ionique différentielle couplée à la MS haute résolution (résonance cyclonique ionique FTICR) et à la photodissociation Infra-rouge. Ce travail nous a permis d’isoler et de caractériser pour la première fois la qBH2, intermédiaire réactionnel fugace de la BH4, impliqué dans le mécanisme d’action de cette dernière. La méthode UHPLC-MS/MS développée, permet en outre le dosage simultané du 5-Méthyl-tétrahydrofolate.
72642_LO_2017_archivage.pdf (4.06 Mo) Télécharger le fichier
tel-01779568 , version 1 (26-04-2018)
  • HAL Id : tel-01779568 , version 1
Aurélien Lo. Développement de méthodes de diagnostic rapide d'erreurs innées du métabolisme associées à des troubles neurologiques. Chimie analytique. Université Paris Saclay (COmUE), 2017. Français. ⟨NNT : 2017SACLS504⟩. ⟨tel-01779568⟩
235 Consultations
1780 Téléchargements
