Identification de deux gènes, WDR73 et UBA5, impliqués dans la déficience intellectuelle sévère syndromique - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2017
Identification of two genes, WDR73 and UBA5, involved in severe syndromic intellectual disability
The prevalence of intellectual disability is estimated between 1% and 3% of the population. In France, mild intellectual disability affects between 10 and 20 per 1,000 people and severe intellectual disability between from 3 to 4 per 1,000 people. Intellectual disability is part of a heterogeneous group of syndromic and nonsyndromic pathologies with limitation in intellectual functioning and adaptive behavior appearing before the age of 18 and causing a disability. The causes of intellectual disability affect neurogenesis and / or neuronal functions. About 50% of intellectual disabilities are still undetermined. Genetic etiologies explain a large number of intellectual disabilities and more particularly the severe forms. New technologies, such as Array- Based Comparative Genomic Hybridization and next generation sequencing, have increased the diagnostic yield to 55-70% in moderate to severe intellectualdisability. Thanks to these techniques, we have been able to identify and characterize two new genes involved in severe autosomal recessive syndrome: the WDR73 gene responsible for Galloway Mowat syndrome which associates severe intellectual disability with corticosteroid-resistant nephrotic syndrome, and the UBA5 gene, involved in the ufmylation process in early encephalopathy.
La prévalence de la déficience intellectuelle est estimée entre 1 à 3% de la population. En France, la déficience intellectuelle légère concerne entre 10 et 20 pour 1 000 personnes et la déficience intellectuelle sévère entre 3 à 4 pour 1 000 personnes. La déficience intellectuelle fait partie d’un groupe hétérogène de pathologies syndromiques et non syndromiques ayant en commun la limitation importante du fonctionnement intellectuel et du comportement adaptatif, apparaissant avant 18 ans et entrainant un handicap. Les causes de la déficience intellectuelle affectent la neurogénèse et/ou le fonctionnement neuronal. Environ 50% des déficiences intellectuelles sont encore à l’heure actuelle d’étiologie indéterminée. Les étiologies génétiques expliquent un grand nombre de déficiences intellectuelles et plus particulièrement les formes sévères. Les nouvellestechnologies, telles que les analyses chromosomiques sur puce à ADN et le séquençage à haut débit de l’ADN, ont permis d’augmenter le rendement diagnostique à 55-70% dans les déficiences intellectuelles modérées à sévères. C’est grâce à ces techniques que nous avons pu identifier puis caractériser deux nouveaux gènes impliqués dans des déficiences intellectuelles sévères syndromiques autosomiques récessives: le gène WDR73 responsable du syndrome de Galloway Mowat associant un déficience intellectuelle sévère et un syndrome néphrotique cortico-résistant et le gèneUBA5, impliqué dans le processus d’ufmylation, dans une encéphalopathie précoce.
these_ColinSTAR.pdf (12.87 Mo) Télécharger le fichier
tel-01779944 , version 1 (27-04-2018)
  • HAL Id : tel-01779944 , version 1
Estelle Colin. Identification de deux gènes, WDR73 et UBA5, impliqués dans la déficience intellectuelle sévère syndromique. Médecine humaine et pathologie. Université d'Angers, 2017. Français. ⟨NNT : 2017ANGE0043⟩. ⟨tel-01779944⟩
304 Consultations
969 Téléchargements
