Âge, durée et enregistrement du métamorphisme de haute pression dans le massif Central - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2017
Timing, duration and record of high-pressure metamorphism in the French massif Central
Caroline Lotout
Subduction is one of the key stages of the mountain building processes. It leads to the development of high-pressure (HP) metamorphism in the rocks that typically equilibrate in the blueschist or eclogite-facies conditions. Dating the HP metamorphism and estimating its intensity is therefore a major challenge when reconstructing geodynamics through time. Through a petrological and geochronological study, this PhD dissertation aims to better constrain conditions, durations and timings of HP metamorphism in the southern French Massif Central (European Variscan Belt). The massifs of Najac, Montagne Noire and Lévézou were investigated by a multi-method geochronological approach (zircon, rutile and apatite U-Pb dating, garnet Lu-Hf and Sm-Nd dating, biotite and muscovite 40Ar-39Ar dating) associated with a petrological analysis including numerical modelling of phase equilibria (Theriak-Domino and THERMOCALC). The Najac eclogites reached 560-630 °C at 15-20 kbar and the prograde part of the highpressure metamorphic event lasted for ~ 7 Myr starting at ~ 383 and peaking at ~ 376 Ma. Eclogites hosted in sillimanite-bearing migmatites in the Montagne Noire dome (French Massif Central) reached c. 750°C, 21 kbar before significant decompression at high temperatures. However, none of the obtained geochronological dates could be associated with the HP event. The study of the Najac massif and the Montagne Noire Dome highlight potential decoupling between the REE and the U-Pb isotopic systems. The emplacement of the protoliths of felsic and mafic HP rocks in the Lévézou Massif was estimated at ca. 470 Ma. HP metamorphism peaked at 21-23 kbar and 680-800°C at ~358 Ma. The subsequent fast exhumation reached 8-9.5 kbar and ~600°C at ~352 Ma, highlighting a very fast exhumation followed by a cooling rate of 50°C/Ma. Granites from the Lévézou massif display kyanite-garnet-muscovite-quartz pseudomorphs after cordierite that equilibrated at ca. 15-17 kbar and ~670°C. The major deformation in these granites is associated with the exhumation stage, locally accompanied by partial melting, and seems to occur in different episodes, from ~352 Ma to ~340 Ma. On a larger scale, these results are fully in line with the HP ages described in the Variscan Belt and allow to reconsider the tectonics in the French Massif Central.
Les processus de subduction sont une étape clé de la formation des orogènes et induisent un métamorphisme de haute pression, localisé dans les faciès des schistes bleus et éclogites. Caractériser la durée et l’intensité de ce métamorphisme est ainsi une étape cruciale puisque amenant des contraintes quantitatives sur la géodynamique d’un orogène. Par une étude pétrologique et géochronologique, cette thèse a ainsi pour objectif de préciser les conditions et durées du métamorphisme de haute pression dans le sud du Massif Central Français (chaîne Varisque), à travers l’étude des massifs de Najac, de la Montagne Noire et du Lévézou. Cette thèse associe ainsi une géochronologie multiméthodes (U-Pb sur zircon, rutile et apatite, Lu-Hf et Sm-Nd sur grenat, 40Ar-39Ar sur biotite et muscovite) à des analyses pétrologiques impliquant des modélisations numériques d’équilibres de phases (Theriak-Domino et THERMOCALC). L’étude d’une éclogite du massif de Najac a ainsi permis de déterminer des conditions de 15 à 20 kbar et 560 à 630°C pour le métamorphisme de haute pression. Le début du faciès éclogite y est daté à ~383 Ma, tandis que le pic du métamorphisme éclogitique est atteint à 375.7 ± 1.2 Ma. La datation des éclogites de la Montagne Noire n’a pas permis de préciser un âge solide de l’évènement de haute pression. Néanmoins, les conditions de pression et température du faciès éclogite y sont estimées à ~ 21 kbar et ~ 750°C. L’étude des massifs de Najac et de la Montagne Noire a mis en évidence de potentiels découplages entre les systèmes de terres rares et le système isotopique U-Pb. Les protolithes des terrains éclogitiques du massif du Lévézou, tant mafiques que felsiques, se sont mis en place à ca. 470 Ma. Le métamorphisme éclogitique affectant les roches mafiques est estimé à 21-23 kbar pour 680- 800°C et atteint à ~358 Ma. L’exhumation, bien caractérisée, y est rapide : les terrains éclogitiques atteignent 8-9.5 kbar et ~600°C à ~352 Ma, impliquant une exhumation très rapide, suivie d’un refroidissement de plus de 50°C/Ma. Les granites du massif du Lévézou présentent des pseudomorphoses de cordiérite à disthène-grenat-muscovite-quartz, développées lors du métamorphisme de haute pression et équilibrées à ca. 15-17 kbar et ~670°C. La déformation majeure observée dans ces granites peut s’accompagner de fusion localisée, et semble se produire en différentes étapes, depuis ~352 Ma à ~340 Ma. Replacées dans un contexte général, ces données s’inscrivent pleinement dans les gammes d’âges de la haute pression décrites pour la chaîne varisque et permettent de reconsidérer la tectonique du Massif Central.
LOTOUT_Caroline.pdf (31.85 Mo) Télécharger le fichier
tel-01810106 , version 1 (25-06-2018)
  • HAL Id : tel-01810106 , version 1
Caroline Lotout. Âge, durée et enregistrement du métamorphisme de haute pression dans le massif Central. Sciences de la Terre. Université de Rennes, 2017. Français. ⟨NNT : 2017REN1S128⟩. ⟨tel-01810106⟩
432 Consultations
200 Téléchargements
