Isomères de position d’indacénodithiophènes : synthèse, propriétés et applications en transistors organiques à effet de champ - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2017
Position isomers of indacenodithiophenes : synthesis, properties and applications in organic field effect transistors
Organic Field Effect Transistors (OFETs), in which the charge transport is carried through a thin film made of organic molecules represent a transformation of the FET technology regarding that based on Silicon. They offer in particular the possibility to manufacture low cost flexible electronics. This work is focused on the synthesis, the study and the use as active layer in n-type OFETs of novel, electron poor, couples of para- and meta-indacenodithiophenes isomers (para- and meta-IDT). First of all, an introduction to the field of n-type OFETs is presented, followed by the presentation of the synthesis of the IDT derivatives and the comparative analysis of their properties. Finally, the fabrication of the OFETs, their characterization and the optimization of their architecture is described. The performances recorded attest that these derivatives are of great interest for the n-type OFETs. Different 3π-2spiro IDT derivatives are also presented in order to study the IDTs intrinsic properties and to envisage their incorporation as host in phosphorescent organic light-emitting diodes.
Les transistors organiques à effet de champ (OFETs) dans lesquels le transport des charges se fait à travers un film mince de molécules organiques représentent une transformation de la technologie des transistors à effet de champ au regard de la technologie au silicium. Ils permettent notamment d’envisager le développement d’une électronique flexible à bas coût. Ce travail porte sur la synthèse, l’étude et l’utilisation en tant que couche active dans des OFETs de type n de couples d’isomères para- et méta-indacénodithiophènes (para- et méta-IDT) appauvris en électrons inédits. Une introduction aux OFETs de type n est tout d’abord présentée. Elle est suivie par la présentation de la synthèse des dérivés IDT et de l’analyse comparée de leurs propriétés physico-chimiques. La fabrication des OFETs, leur caractérisation et l’optimisation de leur architecture est enfin décrite, leurs performances montrant l’intérêt des IDTs pour les OFETs de type n. Différentes fonctionnalisations menant à des IDTs d’architecture 3π-2spiro sont également synthétisées afin d’étudier les propriétés intrinsèques de ces dérivés π-conjugués et d’envisager leur incorporation comme matrice hôte dans des diodes électrophosphorescentes organiques.
PELTIER_Jean-david.pdf (8.23 Mo) Télécharger le fichier
tel-01818107 , version 1 (18-06-2018)
  • HAL Id : tel-01818107 , version 1
Jean-David Peltier. Isomères de position d’indacénodithiophènes : synthèse, propriétés et applications en transistors organiques à effet de champ. Electronique. Université de Rennes, 2017. Français. ⟨NNT : 2017REN1S138⟩. ⟨tel-01818107⟩
158 Consultations
378 Téléchargements
