Compact image vectorization by stochastic approaches - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2018
Vectorisation compacte d’images par approches stochastiques
Artists appreciate vector graphics for their compactness and editability. However many artists express their creativity by sketching, painting or taking photographs. Digitizing these images produces raster graphics. The goal of this thesis is to convert raster graphics into vector graphics that are easy to edit. We cast image vectorization as an energy minimization problem. Our energy is a combination of two terms. The first term measures the fidelity of the vector graphics to the input raster graphics. This term is a standard term for image reconstruction problems. The main novelty is the second term which measures the simplicity of the vector graphics. The simplicity term is global and involves discrete unknowns which makes its minimization challenging. We propose two stochastic optimizations for this formulation: one for the line drawing vectorization problem and another one for the color image vectorization problem. These optimizations start by extracting geometric primitives (skeleton for sketches and segmentation for color images) and then assembling these primitives together to form the vector graphics. In the last chapter we propose a generic optimization method for the problem of geometric shape extraction. This new algorithm does not require any preprocessing step. We show its efficiency in a variety of vision problems including line network extraction, object contouring and image compression.
Les artistes apprécient les images vectorielles car elles sont compactes et facilement manipulables. Cependant, beaucoup d’artistes expriment leur créativité en dessinant, en peignant ou encore en prenant des photographies. Digitaliser ces contenus produit des images rasterisées. L’objectif de cette thèse est de convertir des images rasterisées en images vectorielles qui sont facilement manipulables. Nous avons formulé le problème de vectorisation comme un problème de minimisation d’énergie que nous avons défini par deux termes. Le premier terme, plutôt classique, mesure la fidélité de l’image vectorielle générée avec l’image rasterisée d’origine. La nouveauté principale est le second terme qui mesure la simplicité de l’image vectorielle générée. Le terme de simplicité est global et contient des variables discrètes, ce qui rend sa minimisation difficile. Nous avons proposé deux algorithmes de vectorisation : un pour la vectorisation de croquis et un autre pour la vectorisation multicouches d’images couleurs. Ces deux algorithmes commencent par extraire des primitives géométriques (un squelette pour les croquis et une segmentation pour les images couleurs) qu’ils assemblent ensuite pour former l’image vectorielle. Dans la dernière partie de la thèse, nous proposons un nouvel algorithme qui est capable de vectoriser des croquis sans étapes préliminaires : on extrait et assemble les primitives simultanément. Nous montrons le potentiel de ce nouvel algorithme pour une variété de problèmes de vision par ordinateur comme l’extraction de réseaux linéiques, l’extraction d’objets et la compression d’images.
2018AZUR4004.pdf (89.1 Mo) Télécharger le fichier
tel-01818515 , version 1 (19-06-2018)
  • HAL Id : tel-01818515 , version 1
Jean-Dominique Favreau. Compact image vectorization by stochastic approaches. Signal and Image processing. Université Côte d'Azur, 2018. English. ⟨NNT : 2018AZUR4004⟩. ⟨tel-01818515⟩
402 Consultations
123 Téléchargements
