Structure et fonctionnement hydrogéologiques des massifs de péridotites de Nouvelle-Calédonie - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2017
Structural and hydrogeologic characterization of the peridotitic massifs of New Caledonia
Julie Jeanpert
Water resources of hard-rock (gneisses or granites) aquifers have significantly been studied in the past two decades. The hydrogeological behavior and structure of these aquifers are thus relatively well understood. On the other hand, aquifers in mantle-type basements, such as peridotites, are poorly studied and understood, mainly because they are not common and of limited extent. In this context, New Caledonia is a great laboratory offering unique opportunity to improve the knowledge of these original types of hydrosystems in tropical climate. Thus, the objective of this thesis is to improve the knowledge of these aquifer systems within weathered peridotites. Firstly, the study focuses on the characterization of the weathered layers of the peridotites composed of, from top to bottom, iron oxides/ferricrete, laterite, coarse saprolite and saprock (ie. top of the bedrock, with up to 20 % of weathered material). More than 60 hydraulic tests are performed and results were compiled with existing data. Mean hydraulic conductivity (K) of laterites is estimated around 1.10-7 m/s while mean value in coarse saprolites and saprock is around 8.10-7 m/s. Heterogeneity of this altered layer is high; K varies between six orders of magnitude and hydraulic head data analysis reveals a hydraulic connection with the deep fractured bedrock. Secondly, the fresh rock part of peridotites is studied. Fracture network analysis is derived from outcrop structural measurements and from the description of about 1000 m of cumulated borehole cores. This work highlights the importance of serpentine network, because of its high density and its critical impact on weathering. Moreover, the observations reveal that hydraulic conductivity decreases with depth within the substratum, due to the vertical decrease of weathered fractures density. These new results allow defining a structural framework of the massifs. It is characterized by a primary decimetrical fracture network closely related to the serpentine network. This network is overprinted by a secondary weathering network which reveals decametric spacing (ca. 30 m) and in places K values of 10-5 m/s. At depth, spacing is hectometrical and fractures are sealed by lithostatic pressure and/or subsequent mineral precipitations. These deca- and hectometric fracture networks, which are also visible on the scale effect of hydraulic conductivity, are primarily vertical and are the result of dissolution instabilities occurring during weathering processes. However, low- angle fractures do occur and allow the percolation of the network. Finally, on the basis of these new results and the integration of all existing data from different massifs a new hydrogeological conceptual model is proposed at the scale of a massif. The model includes a homogeneous lateritic aquitard and a coarse saprolite and saprock aquifer which is about 50 m thick. The bedrock is subdivided into three layers whose hydraulic conductivity decreases from 2.10-7 m/s to 2.10-8 m/s, respectively 50 and 250 m below the aquifer base. Numerical modelling validates this unitary conceptual model and reveals that the saturation of the massifs depends on their morphology. At last, several aspects require further research. The role of the ferricrete layer must be specified and considered in the hydrological model. Moreover, distribution of the fracture network remains to be fully addressed and should be studied with care given the potential development of highly permeable structures that could conform to pseudo-karstic drains. The applied results of this work are available in a “Technical guide” and a “Technical report” of the “HYPERK” CNRT Project.
Le fonctionnement et la structure hydrogéologiques des aquifères de socle des granites et des gneiss sont aujourd'hui relativement bien compris. En revanche, dans cet ensemble, les aquifères dans les péridotites sont très peu étudiés et mal compris. Dans ce contexte, les massifs obductés de Nouvelle-Calédonie présentent un laboratoire naturel exceptionnel pour améliorer la connaissance de cet hydrosystème original en contexte tropical. Ainsi l'objectif du présent travail de thèse est d'approfondir la connaissance de la structure et du fonctionnement hydrogéologiques de ces massifs. L'analyse porte d’abord sur le manteau d'altération constitué de la cuirasse, des latérites, des saprolites grossières et du saprock. Plus de 60 essais hydrauliques sont menés sur les massifs de péridotites et les résultats sont compilés aux données existantes. La conductivité hydraulique moyenne des latérites est évaluée à 1.10-7 m/s et celle des saprolites grossières et du saprock à 8.10-7 m/s. L'hétérogénéité de cet horizon altéré est marquée par une gamme de variation de la conductivité hydraulique sur six ordres de grandeur et l'analyse piézométrique met en évidence des connexions hydrauliques avec le substratum fracturé profond. Le substratum est ensuite considéré. L'étude de la fracturation est réalisée à partir de mesures structurales sur affleurement et de la description de près de 1000 m de carottes de forages. L'analyse de la fracturation met en évidence l'importance du réseau serpentineux par sa densité d’une part, et par son lien avec l'altération supergène d'autre part. De plus, il est vérifié que la conductivité hydraulique du substratum diminue avec la profondeur. Cette variation est liée à la diminution de la densité de fractures altérées. Ainsi, à l'issue de ces analyses, la structure des massifs de péridotites est définie. Un réseau primaire de fractures d’espacement décimétrique lié au réseau serpentineux préstructure les péridotites. Sur ce réseau se surimpose un réseau de fractures dont l'espacement est décamétrique et caractérisé par une altération supergène. Les fractures altérées présentent localement de fortes conductivités hydrauliques, de l'ordre de 10-5 m/s. En profondeur l'espacement des fractures est hectométrique et les fractures sont majoritairement fermées, scellées par les minéraux néoformés ou par l'effet de la pression lithostatique. Les réseaux de fractures déca et hectométriques, visibles également sur l'effet d’échelle de la conductivité hydraulique, sont majoritairement verticaux, développés par instabilité de dissolution lors des processus d’altération. Cependant, des structures à faible pendage existent également et permettent la percolation du réseau. Enfin, à partir de ces nouveaux résultats et de l’intégration de l'ensemble des données acquises sur les différents massifs, un modèle de structure et de fonctionnement hydrogéologiques est proposé à l'échelle du massif. Ce modèle comprend l'horizon des latérites qui constitue un aquitard homogène sous lequel se développe l'aquifère dont l'épaisseur est de l'ordre de cinquante mètres. Le substratum est discrétisé en trois couches dont la conductivité hydraulique décroît de 2.10-7 à 2.10-8 m/s entre 50 m et 250 m environ sous le mur de l'aquifère. Les modèles numériques construits permettent de valider le modèle conceptuel unitaire et montrent que l'état de saturation des massifs est contraint par leur géomorphologie. Au terme de ce travail, plusieurs aspects doivent encore être approfondis. Le rôle hydrogéologique de la cuirasse doit être précisé et considéré dans le modèle hydrogéologique. Enfin, compte tenu du développement possible de structures très perméables, voire pseudo-karstiques, la connaissance de la distribution des structures drainantes doit être améliorée. Les résultats appliqués de ce travail de recherche sont exposés dans un rapport final et un guide méthodologique livrés dans le cadre du projet CNRT « HYPERK ».
2017lare0047_JJeanpert.pdf (23.72 Mo) Télécharger le fichier
tel-01845503 , version 1 (20-07-2018)
  • HAL Id : tel-01845503 , version 1
Julie Jeanpert. Structure et fonctionnement hydrogéologiques des massifs de péridotites de Nouvelle-Calédonie. Sciences de la Terre. Université de la Réunion, 2017. Français. ⟨NNT : 2017LARE0047⟩. ⟨tel-01845503⟩
355 Consultations
231 Téléchargements
