Rôle écologique de la sporulation in-planta dans les symbioses actinorhiziennes : cas de la symbiose Alnus - Frankia - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2018
Ecological role of the in-planta sporulation in the actinorhizal symbiosis : case of the Alnus-Frankia symbiosis
Microbial biogeography would be based on the ability of microorganisms to disperse across time and space, as a function of abiotic factors such as soil properties, climate, and of biotic interactions, in particular with the host in the case of symbionts, but also on life history traits such as the ability to sporulate. Frankia sp. is a spore-forming and nitrogen-fixing actinobacterium that has a complex biogeography given its abilities for both saprophytic life and root symbiotic interaction with actinorhizal plants such as alders (Alnus, Betulaceae). Two distinct groups of Frankia lineages have been described according to a major phenotypic divergence, based on the presence (Sp+) or the absence (Sp-) of spores in planta.. To the best of our knowledge, this endophytic sporulation is an original trait in a symbiotic context and very little is known about its incidence in Frankia biogeography. This work integrates descriptive and experimental approaches on both field and laboratory areas, in order to improve the understanding of the ecological role of Frankia in planta sporulation. First, we have extended the description of the phylobiogeography of Sp+ Frankia strains to validate the previously proposed distribution pattern focused on cold environements at high altitude or high latitude. A phylogeny has been computed using a large number of nodular strains coming from the 3 continents of the Northern Hemisphere and 10 different Alnus species. Special attention was paid to geographic areas where a higher diversity was expected, in Asia, and in its glacial refuges. Second, we studied the influence of the host-plant on the distribution of Fankia Sp+ and the incidence of Sp+ in the symbiotic interaction. Experimental crosses have been performed to disentangle host and climate effects and to test the incidence of the Sp+ trait in terms of infectivity, competitiveness and host-range. Finally, we studied the ecological consequences of the Alnus/Frankia symbiotic complex, on the microbial diversity and on the nitrogen cycle functionning, with respect to the sporulation of Frankia and to the Alnus expansion on sub-/alpine grasslands. Soils analyses were performed in association with measures of nitrification and denitrification, as well as global and functional microbial diversity analyses, in Sp+, Sp- or mixed alder stands and at different colonization stages. In each part of this work, alder ectomycorhizae were analyzed to compare the distribution pattern between the two symbionts and to highlight potential interactions with the Sp+ trait of Frankia. Our results show the dominance of Sp+ strains in nodules of alder species from cold environments over the 3 continents of the Holarctic zone, with original diversity patterns in alder area of origin and in glacial refuges. Even if these strains are genetically homogenous, host-specific clusters were observed in the phylogeny. Crosses revealed that Sp+ strains were more infective and competitive than Sp- strains. Moreover, unlike Sp- strains that harbor a wide host-range, Sp+ strains have a narrower specificity leading to association’s incompatibilities and suggesting strong host dependence. For the first time, modifications of microbial communities were revealed in response to the Alnus-Frankia symbiotic complex colonization and were linked to a stimulation of the nitrogen cycle in the sub-/alpine grasslands. The first comparative results of nitrogen fixation between Sp+ and Sp- strains in natura suggest a maximal efficiency of fixation, representing almost 100% of the alder nitrogen. However, unlike previous reports in literature, no pattern was observed between Sp+ and Sp- strains, suggesting a complex effect of seasonality, alder age as well as that of nodules. Altogether, the previous results contribute to a better understanding of the Frankia biogeography drivers and allow us to discuss the expected evolution of distribution pattern in response to the global warming
Les patrons de distribution chez les micro-organismes reposeraient sur leurs capacités à disperser dans le temps et dans l'espace, en lien avec des facteurs abiotiques comme les propriétés du sol, le climat, et des interactions biotiques, notamment avec l'hôte dans le cas des symbiontes, mais aussi sur les traits d'histoire de vie propres aux micro-organismes, telle que la capacité à sporuler. Frankia sp. est une actinobactérie sporulante et fixatrice d'azote à la biogéographie complexe, car vivant à la fois de façon saprophytique dans le sol, en symbiose racinaire (nodosité) avec les plantes actinorhiziennes dont les aulnes (Alnus, Betulaceae). Deux types de souches de Frankia génétiquement différentes ont été décrites dont la distinction phénotypique majeure réside dans la capacité à maintenir (Sp+) ou non (Sp-) leur sporulation in planta. Cette sporulation endophytique est à notre connaissance unique dans un contexte symbiotique et son implication dans la biogéographie de Frankia, reste peu connue. Ces travaux de thèse intègrent à la fois des approches descriptives et expérimentales, sur le terrain et au laboratoire, afin d'accroître la compréhension du rôle écologique de la sporulation in planta de Frankia. Dans un premier temps, nous avons étendu la description de la phylobiogéographie des souches de Frankia Sp+ afin de tester la validité du patron de distribution centré sur les milieux froids des zones de haute altitude et de haute latitude de l'hémisphère nord. Un intérêt tout particulier a été porté sur les aires géographiques où une plus forte diversité de Frankia était attendue, dans la zone d'origine de l'aulne et ses refuges glaciaires. Dans un second temps, nous avons étudié l'influence du partenaire végétal dans la distribution observée des Frankia Sp+ et l'implication du trait Sp+ dans la capacité d'association à l'hôte. Des croisements expérimentaux ont été réalisés au laboratoire afin de découpler les effets de l'espèce-hôte et du climat, et tester les implications du trait Sp+ en termes d'infectivité, compétitivité et spectre d'hôte. Enfin, nous avons étudié les conséquences écosystémiques de l'expansion subalpine du complexe symbiotique Alnus/Frankia, au niveau de la diversité microbienne et du fonctionnement du cycle de l'azote, en fonction du phénotype de sporulation des souches associées. Des analyses pédologiques, en association avec des mesures de nitrification, dénitrification et fixation d'azote, ainsi que des analyses de diversité microbienne (globale et fonctionnelle), ont été réalisées dans différentes aulnaies Sp+, Sp- ou mixte, à différents stades de colonisation de l'aulne. Les résultats obtenus démontrent une prédominance des souches Sp+ associées aux espèces d'aulne des milieux froids sur les 3 continents de la zone Holarctique, avec une diversité nouvelle dans l'aire d'origine et les zones refuges de l'aulne. Les croisements effectués révèlent une infectivité et compétitivité plus forte des Sp+ par rapport aux Sp-. De plus, contrairement aux Sp- à spectre d'hôte très large, les Sp+ présentent un spectre limité entraînant des incompatibilités d'association suggérant une dépendance forte à une espèce-hôte donnée. Les modifications des communautés microbiennes du sol en réponse à l'expansion du complexe symbiotique Alnus/Frankia ont été démontrées, en lien avec la stimulation du cycle de l'azote dans les milieux sub-/alpins. Les premiers résultats sur l'efficience comparée de la fixation d'azote in natura des souches Sp- par rapport aux Sp+ suggèrent que 100% de l'azote de l'aulne est obtenu par le biais de la fixation. Aucun patron n'est mis en évidence entre souches Sp+ et Sp-, suggérant un effet plus complexe de la saisonnalité, de l'âge de l'arbre et de celui de la nodosité. Les résultats obtenus nous permettent de mieux appréhender les facteurs guidant la biogéographie de Frankia et de discuter de l'évolution de ces patrons de distribution en réponse au réchauffement climatique
TH2018SchwobGuillaume.pdf (46.29 Mo) Télécharger le fichier
tel-01858126 , version 1 (20-08-2018)
  • HAL Id : tel-01858126 , version 1
Guillaume Schwob. Rôle écologique de la sporulation in-planta dans les symbioses actinorhiziennes : cas de la symbiose Alnus - Frankia. Ecologie, Environnement. Université de Lyon, 2018. Français. ⟨NNT : 2018LYSE1037⟩. ⟨tel-01858126⟩
295 Consultations
124 Téléchargements
