Simulation numérique du processus d’assemblage de câbles flexibles en grands déplacements - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2018
Numerical simulation of the assembly process of flexible cables under large displacements
With on-board electronics expansion, electrical cables are an essential partof automotive pieces and the space on board has plummeted. Their flexibility requires to predict their deformation during vehicle assembly in order to avoid the contact with other pieces and damaging. Current numerical tools do not allow a realistic and accurate prediction, which is necessary in the obstructed car space. Assembly steps thus are validated on costly physical mock-ups. This thesis aims at improving numerical simulation of these flexible pieces. We herein propose a 3D algorithm based on a geometrically exact beam model solved by the finite element method. This work’s originality stands in coupling quaternions as rotational parameters and the asymptotic numerical method as nonlinear solver which results in a very robust algorithm. A test bench designed to identify the homogenized beam parameters of the numerical model and to validate it by offering a comparison on the final geometry and the equilibrium path is presented. Analytical developments on shear beams and the results of these experimental tests lead to a critical evaluation of the 3D Timoshenko model for representing stranded cables.
Avec l’essor de l’électronique embarquée, les câbles électriques constituentune part importante des pièces automobiles tandis que l’espace à bord n’a cessé de diminuer. Leur flexibilité requiert la prédiction de leur déformation durant leur montage afin d’éviter le contact avec d’autres pièces du véhicule et leur endommagement. Les outils actuels ne permettent pas une prédiction assez réaliste et précise de leur comportement, nécessaire dans un volume de travail très restreint. Les étapes de montage sont donc validées via la réalisation de maquettes réelles coûteuses. Cette thèsea pour but d’améliorer la simulation numérique de ces pièces souples. Nous proposonsici un code de simulation 3D basé sur un modèle de poutre géométriquement exact résolu par la méthode des éléments finis. Son originalité tient dans le couplage des quaternions pour modéliser les rotations 3D et de la méthode asymptotique numérique pour la continuation du système non linéaire qui lui confère une grande robustesse. Un banc d’essai permettant l’identification des paramètres homogénéisés nécessaires au modèle numérique et sa validation par comparaison de la géométrie finale et du chemin d’équilibre est présenté. Combinés à des développements analytiques sur les modèles de poutres avec cisaillement, les essais mènent à une évaluation critique du modèle deTimoshenko 3D pour la représentation des torons de câbles.
COTTANCEAU.pdf (110.33 Mo) Télécharger le fichier
tel-01877657 , version 1 (20-09-2018)
  • HAL Id : tel-01877657 , version 1
Emmanuel Cottanceau. Simulation numérique du processus d’assemblage de câbles flexibles en grands déplacements. Génie mécanique [physics.class-ph]. Ecole nationale supérieure d'arts et métiers - ENSAM, 2018. Français. ⟨NNT : 2018ENAM0011⟩. ⟨tel-01877657⟩
444 Consultations
159 Téléchargements
