Mise en évidence des propriétés chimiotactiques de l’oxygène pour des cellules épithéliales : implication du récepteur EGFR dans l’aérotaxie - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2017
Identification of chemoattractant capacities of oxygen for epithelial cells : involvement of EGF receptor in aerotaxis
Cell migration is a crucial process during embryonic development, wound healing, immune system but also metastasis. Success of these processes relies on the capacities of cells to sense an asymmetric signal, interpret it and orient themselves to migrate in a directed manner. In vivo, migration is guided by several signals from the cellular microenvironment. Hypoxia, or decrease in the level of tissue oxygen, is an important feature of the cellular environment in the embryo and in solid tumors. Owing to the limitation of oxygen diffusion, hypoxia often generates oxygen gradients in vivo. We have developed an original method in which epithelial cells themselves generate oxygen gradient in vitro. And interestingly, these cells are able to migrate directionally to higher oxygen concentrations. This aerotaxis ability is independent of mitochondrial respiration and hypoxia response pathway. The reactive oxygen species (ROS) would mediate the migratory response to the gradient. The asymmetric production of ROS between the front and the back of the cells would be at the origin of the differential activation of the EGFR receptor and the persistence of cells towards higher oxygen concentrations. This chemoattractant capacity of oxygen, known in bacteria, but not described for eukaryotic cells, could play a major role in embryonic development and in metastatic dissemination
La migration cellulaire dirigée est un processus crucial lors du développement embryonnaire, de la cicatrisation, de la réponse immunitaire mais aussi lors de la formation de métastases. La réussite de ces processus nécessite que les cellules perçoivent un signal asymétrique, l'interprète et s'oriente pour migrer de façon dirigée. In vivo, la migration est dirigée par de nombreux signaux du microenvironnement cellulaire. L'hypoxie, ou diminution du niveau d'oxygène tissulaire, est une caractéristique importante de l'environnement cellulaire dans l'embryon et dans les tumeurs solides. Du fait de la limitation de la diffusion de l'oxygène, l'hypoxie génère in vivo des gradients d'oxygène. Nous avons développé une méthode originale dans laquelle des cellules épithéliales génèrent elles-mêmes gradient d'oxygène in vitro. Et de façon très intéressante, ces cellules sont capables de migrer de façon directionnelle vers des concentrations en oxygène plus élevées. Cette capacité d'aérotaxie est indépendante de la respiration mitochondriale et des acteurs de réponse à l'hypoxie. Les dérivés réactifs de l'oxygène (ROS) seraient les médiateurs de la réponse migratoire au gradient. La production asymétrique de ROS entre l'avant et l'arrière des cellules serait à l'origine de l'activation différentielle du récepteur EGFR et de la persistance des cellules vers des concentrations plus importantes en oxygène. Cette capacité chimio-attractante de l'oxygène, connue chez les bactéries, mais non décrite pour des cellules eucaryotes, pourrait jouer un rôle majeur lors du développement embryonnaire et dans la dissémination métastatique
TH2017DEYGASMATHIEU.pdf (32.81 Mo) Télécharger le fichier
tel-01879097 , version 1 (22-09-2018)
tel-01879097 , version 2 (24-09-2018)
  • HAL Id : tel-01879097 , version 2
Mathieu Deygas. Mise en évidence des propriétés chimiotactiques de l’oxygène pour des cellules épithéliales : implication du récepteur EGFR dans l’aérotaxie. Biologie cellulaire. Université de Lyon, 2017. Français. ⟨NNT : 2017LYSE1261⟩. ⟨tel-01879097v2⟩
375 Consultations
31 Téléchargements
