Long-lasting effects of operant conditioning and cocaine on D1 pyramidal neurons in prefrontal cortex and on the D1 and D2 striatal neurons mRNAs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2016
Effets à long terme du conditionnement opérant et de la cocaïne sur les ARNm dans les neurones d1 du cortex préfrontal et les neurones d1 et d2 du striatum
Dopamine (DA) controls movement execution, action selection, and incentive learning by regulating the activity and plasticity of corticostriatal transmission. Long-term modifications require changes in gene transcription. The aim of this work is to study the changes in transcriptions following an operant learning protocol or mimicking stimulation of the reward system with cocaine in the dorsal striatum and the nucleus accumbens in the striatum, and in the prefrontal cortex. The medium-size spiny striatal projection neurons (SPNs) can be divided into 2 different populations based on the expression of the D1 or D2 DA receptor that participate in distinct pathways, which have opposite functional effects on their target regions. We used transgenic mice that express a tagged ribosomal protein (L10a-EGFP) under control of the D1 or D2 receptor promoter to isolate currently translated mRNA and nuclei from each population of SPNs, as well as from D1 neurons of the prefrontal cortex following passive stimulation of the reward system (chronic treatment with cocaine) and active recruitment of the reward system (operant learning for food). Firstly we compared the basal gene expression in the different neuronal populations characterized by the expression of D1 or D2 receptors and their regional localization. We identified hundreds of differentially expressed mRNA providing a precise characterization of the cellular and regional differences. In the second part, we characterized the changes induced in each neuronal population by a 1-week exposure to cocaine or after operant training for food.
La dopamine (DA) contrôle l'apprentissage lié à la récompense en régulant l'activité et la plasticité de la transmission corticostrialale. Les effets à long terme de la DA impliquent des changements dans la transcription des gènes. Le but de ce travail de thèse est d'étudier les changements transcriptionnels produit dans le striatum ventral, dorsal et cortex préfrontal, par un protocole d'apprentissage opérant ou après une activation du système de la récompense par des injections de cocaïne. Les neurones épineux moyens du striatum peuvent être séparé en deux populations fonctionnelles sur la base de l'expression du récepteur de type 1 de la DA (D1R) ou de type 2 (D2R). Des souris transgéniques expriment une protéine ribosomale étiqueté avec la GFP sous le contrôle du promoteur de D1R ou D2R ont été utilisés afin d'isoler les ARN messagers (ARNm) des neurones D1 ou D2. La première partie de ce travail est centré sur la comparaison de l'expression des gènes dans les différentes populations neuronales exprimant le D1R ou D2R appartenant aux différentes régions d'intérêt, ce qui apporte une caractérisation précise nouvelle des neurones cibles de la DA. Dans un deuxième temps, nous avons caractérisé les modifications produites dans chaque population neuronale par une stimulation passive du système de récompense (traitement chronique à la cocaïne) ou un recrutement actif (apprentissage opérant pour la nourriture).
2016PA066723.pdf (98.99 Mo) Télécharger le fichier
tel-01879536 , version 1 (24-09-2018)
tel-01879536 , version 2 (24-09-2019)
  • HAL Id : tel-01879536 , version 2
Enrica Montalban. Long-lasting effects of operant conditioning and cocaine on D1 pyramidal neurons in prefrontal cortex and on the D1 and D2 striatal neurons mRNAs. Neurons and Cognition [q-bio.NC]. Université Pierre et Marie Curie - Paris VI, 2016. English. ⟨NNT : 2016PA066723⟩. ⟨tel-01879536v2⟩
262 Consultations
16 Téléchargements
