Caractérisation fonctionnelle du récepteur de type 2 de la neurotensine dans la résistance à la mort cellulaire des lymphocytes B au cours de la Leucémie Lymphoïde Chronique - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2017
Functional characterization of neurotensin type 2 receptor in cell death-resistance of chronic lymphocytic leukemia B cells
Chronic lymphocytic leukemia (CLL) is characterized by the abnormal accumulation of mature B lymphocytes. Current therapies for CLL rely on using kinase inhibitors targeting B-cell receptor (BCR) pathways, but they are limited by the high level of apoptosis-resistant B-CLL cells, which results in a high frequency of patient relapse. Because current therapies fail to eradicate these apoptosis-resistant cells, it is essential to identify alternative survival pathways as novel targets for anticancer therapies. Overexpression of cell-surface G protein-coupled receptors (GPCRs) drives cell transformation, and thus plays a critical role in malignancies. In this study, we show that neurotensin receptor 2 (NTSR2), a G-protein-coupled receptor, is an essential driver of apoptosis resistance in B-CLL. NTSR2 was highly expressed and constitutively active in B-CLL cells, and its activation depended on its interaction with the tropomyosin-related kinase B receptor (TrkB) and the recruitment of Gi proteins, instead of its interaction with its natural ligand, neurotensin (NTS). The NTSR2-TrkB interaction acted as a conditional oncogenic driver requiring the TrkB ligand BDNF (Brain-Derived Neurotrophic Factor), which is highly expressed in B-CLL cells, unlike its natural ligand NTS. The NTSR2-TrkB interaction activates survival signaling pathways, including the Src and AKT kinase pathways, as well as expression of the anti-apoptotic proteins Bcl-2 (B-cell lymphoma-2) and Bcl-xL (B-cell lymphoma-extra large). TrkB failed to protect B-CLL cells from a drastic decrease in viability via typical apoptotic cell death when NTSR2 was down-regulated. Taken together, the results suggest that the NTSR2-TrKB interaction and the sustained activation of signaling pathways reliant on this interaction constitute an essential driving force for apoptosis evasion of B-CLL cells. Targeting NTSR2 could represent a promising strategy for treating B-CLL malignancy.
La leucémie lymphoïde chronique (LLC) est caractérisée par une accumulation anormale de lymphocytes B matures. Les thérapies actuelles reposent sur l'utilisation d'inhibiteurs ciblant les kinases impliquées dans la voie du récepteur des cellules B (BCR), mais elles sont limitées par le niveau élevé de résistance à l’apoptose des cellules leucémiques. En effet, celles-ci échouent à éradiquer les cellules résistantes à l'apoptose, il est donc essentiel d'identifier d'autres voies de survie comme nouvelles cibles pour les thérapies anticancéreuses. La surexpression des récepteurs de surface couplés aux protéines G (RCPGs) entraîne une transformation cellulaire et joue ainsi un rôle essentiel dans les tumeurs malignes. Dans cette étude, nous montrons que le récepteur de la neurotensine de type 2 (NTSR2), un récepteur couplé aux protéines G, est un acteur essentiel dans les mécanismes de résistance à l'apoptose dans les cellules leucémiques. Le récepteur NTSR2 est surexprimé et constitutivement actif dans les cellules leucémiques, son activation dépend de son interaction avec le récepteur TrkB (Tropomyosin-related kinase B) et du recrutement des protéines Giα à la place de son interaction avec son ligand naturel, la neurotensine (NTS). L'interaction NTSR2-TrkB agit comme un oncogène conditionnel nécessitant le BDNF (Brain-Derived Neurotrophic Factor), le ligand de TrkB, qui est fortement exprimé dans les cellules B leucémiques, contrairement à son ligand naturel la NTS. L'interaction NTSR2-TrkB active les voies de signalisation de survie, y compris les voies de Src et Akt, ainsi que l'expression des protéines anti-apoptotiques Bcl-2 (B-cell lymphoma-2) et Bcl-xL (B-cell lymphoma-extra large). Néanmoins le récepteur TrkB seul ne protège pas les cellules B leucémiques d'une diminution drastique de la viabilité par apoptose lorsque NTSR2 est inactivé. L’ensemble de ces résultats suggèrent que l'interaction NTSR2-TrKB et l'activation soutenue des voies de signalisation dépendante de cette interaction constituent un mécanisme essentiel d’échappement à l'apoptose des cellules B leucémiques. Le ciblage du récepteur NTSR2 représente une stratégie prometteuse pour le traitement de cette pathologie.
2017LIMO0029.pdf (17.29 Mo) Télécharger le fichier
tel-01881459 , version 1 (26-09-2018)
  • HAL Id : tel-01881459 , version 1
Amazigh Abbaci. Caractérisation fonctionnelle du récepteur de type 2 de la neurotensine dans la résistance à la mort cellulaire des lymphocytes B au cours de la Leucémie Lymphoïde Chronique. Médecine humaine et pathologie. Université de Limoges, 2017. Français. ⟨NNT : 2017LIMO0029⟩. ⟨tel-01881459⟩
218 Consultations
139 Téléchargements
