Program in Coq - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2018
Program in Coq
Programmer en Coq
In this thesis, we develop new techniques to conveniently write formally verified programs. To proceed, we study the use of Coq as a programming language in different settings. Coq being a purely functional language, we mainly focus on the representation and on the specification of impure effects, like exceptions, mutable references, inputs-outputs, and concurrency. First, we work on two preliminary projects helping us to understand the challenges of programming in Coq. The first project, Cybele, is a Coq plugin to write efficient proofs by reflection with effects. We compile and execute the impure effects in OCaml to generate a prophecy, a kind of certificate, and then interpret the effects in Coq using the prophecy. The second project, the compiler CoqOfOCaml, imports OCaml programs with effects into Coq, using an effect inference system. Next, we describe different generic and composable representations of impure effects in Coq. The breakable computations combine the standard exceptions and mutable references effects, with a pause mechanism to make explicit the evaluation steps in order to represent the concurrent evaluation of two terms. By implementing the Pluto web server in Coq, we realize that the most important effects to program are the asynchronous inputs-outputs. Indeed, these effects are ubiquitous and cannot be encoded in a purely functional manner. Thus, we design the asynchronous computations as a first way to represent and compile programs with events and handlers in Coq. Then, we study techniques to prove properties about programs with effects. We start with the verification of the blog system ChickBlog written in the language of the interactive computations. This blog runs one worker with synchronous inputs-outputs per client. We verify our blog using the method of specification by use cases. We adapt this technique to type theory by expressing a use case as a well-typed co-program over the program we verify. Thanks to this formalism, we can present a use case as a symbolic test program and symbolically debug it, step by step, using the interactive proof mode of Coq. To our knowledge, this is the first such adaptation of the use case specifications in type theory. We believe that the formal specification by use cases is one of the keys to verify effectful programs, as the method of use cases proved to be convenient to express (informal) specifications in the software industry. We extend our formalism to concurrent and potentially non-terminating programs with the language of concurrent computations. Apart from the use case method, we design a model-checker to verify the deadlock freedom of concurrent computations, by compiling the parallel composition to the non-deterministic choice operator using the language of blocking computations.
Dans cette thèse, nous cherchons à développer de nouvelles techniques pour écrire plus simplement des programmes formellement vérifiés. Nous procédons en étudiant l'utilisation de Coq en tant que langage de programmation dans différents environnements. Coq étant un langage purement fonctionnel, nous nous concentrons surtout sur la représentation et la spécification d'effets impurs, tel que les exceptions, les références mutables, les entrées-sorties et la concurrence. Nous travaillons premièrement sur deux projets préliminaires qui nous aident à comprendre les défis existants dans la programmation en Coq. Le premier projet, Cybele, est un plugin Coq pour écrire des preuves par réflexion efficaces avec effets. Nous compilons et nous exécutons les effets impurs en OCaml pour générer une prophétie, une forme de certificat, et interprétons les effets dans Coq en utilisant cette prophétie. Le second projet, le compilateur CoqOfOCaml, importe des programmes OCaml avec effets dans Coq en utilisant un système d'inférence d'effets. Puis nous décrivons différentes représentations génériques et composables d'effets impurs en Coq. Les calculs avec pause combinent les effets d'exceptions et de références mutables avec un mécanisme de pause. Ce mécanisme de pause permet de rendre explicite les étapes d'évaluation dans le but de représenter l'évaluation concurrente de deux termes. En implémentant le serveur web Pluto en Coq, nous réalisons que les entrées-sorties asynchrones sont l'effet le plus utile : cet effet est présent dans la plupart des programmes et ne peux être encodé de façon purement fonctionnelle. Nous concevons alors les "calculs asynchrones" comme moyen pour représenter et compiler des programmes avec événements en Coq. Finalement, nous étudions des techniques pour prouver des propriétés à propos de programmes avec effets. Nous commençons avec la vérification du système de blog ChickBlog écrit dans le langage des "calculs interactifs". Ce blog lance un fil d'exécution par client. Nous vérifions notre blog en utilisant une méthode de spécification par cas d'utilisation. Nous adaptons cette technique à la théorie des types en exprimant un cas d'utilisation comme un co-programme bien typé. Grâce à ce formalisme, nous pouvons présenter un cas d'utilisation comme un programme de test symbolique et le déboguer symboliquement, étape par étape, en utilisant le mode interactif de Coq. À notre connaissance, ceci représente la première telle adaptation de la spécification par cas d'utilisation en théorie des types. Nous pensons que la spécification formelle par cas d'utilisation est l'une des clés pour vérifier des programmes avec effets, sachant que la méthode des cas d'utilisation s'est avérée utile dans l'industrie pour exprimer des spécifications informelles. Nous étendons notre formalisme aux programmes concurrents et potentiellement non-terminants, avec le langage des "calculs con-currents". Nous concevons également un vérificateur de modèles pour vérifier l'absence d'interblocage dans un programme concurrent, en compilant la composition parallèle vers l'opérateur de choix non-déterministe.
these.pdf (1.09 Mo) Télécharger le fichier
tel-01890983 , version 1 (19-12-2018)
tel-01890983 , version 2 (15-07-2019)
  • HAL Id : tel-01890983 , version 1
Guillaume Claret. Program in Coq. Programming Languages [cs.PL]. Université Paris Diderot - Paris 7, 2018. English. ⟨NNT : ⟩. ⟨tel-01890983v1⟩
Collections
INRIA
370 Consultations
525 Téléchargements
