Matériaux sans plomb micro structurés pour la récupération d'énergie - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2018
Lead-free microstructured materials for energy harvesting
With the development of ultra-low-power integrated circuits, the need to reduce operating costs for embedded electronic devices, and since used batteries pose a threat to the environment, the concept of energy harvesting has gained a new relevance. Energy harvesting covers the scavenging of many lost ambient energy sources and their conversion into electrical energy. A broad range of energy harvesting devices has been developed to scavenge energy from mechanical vibrations. A common configuration consists of a spring-mass system with a piezoelectric material in parallel with the spring to convert some of the mechanical energy during oscillations into electrical power. So far the most used material for piezoelectric energy harvesting is the Lead Zirconate Titanate (PbZr1-xTixO3) (PZT). PZT is the reference material for MEMS (MechanoElectroMechanicalSystems) applications in the field of energy harvesting. Lead-based piezoelectric materials such as PZT and lead magnesium niobate-lead titanate (PMN-PT) offer incomparable piezoelectric coupling factors to other materials. However, despite its excellent electrical properties (dielectric, ferroelectric and piezoelectric), PZT and other Lead based materials should be replaced shortly by leadfree compounds, due to environmental issues. Our work aims at developing lead-free high performance vibration energy-harvesting. We focus on the fabrication and characterization of aluminum nitride (AlN), Barium titanate BaTiO3 (BTO) and Bismuth ferrite BiFeO3 (BFO) devices for energy harvesting. PZT (as a reference because it’s high piezoelectric coefficients), BTO, BFO and AlN have been deposited using sputtering methods, leading to high homogeneous, large scale thin films with a precisely controlled thickness. The deposition of 300nm-thick films by sputtering or spin coating was performed on SrTiO3 (STO) substrate with SrRuO3 (SRO) bottom electrode, which is the reference substrate for the functional oxides (PZT, BTO and BFO), and platinum coated silicon substrate, which is the classic industrial template. Whatever the piezoelectric materials, we obtained epitaxial films on STO substrate and textured films on silicon substrate. Structural, electrical and piezoelectric measurements on the BTO, AlN and PZT films show that they have good physical properties in agreement with the literature.
Avec le développement des circuits intégrés à très faible consommation d'énergie, la nécessité de réduire les coûts d'exploitation des dispositifs électroniques embarqués et l'utilisation des piles usagées constituant une menace pour l'environnement, le concept de récupération d'énergie a acquis un nouvel intérêt. La récupération d'énergie couvre le piégeage de nombreuses sources d'énergie ambiantes perdues et leur conversion en énergie électrique. Une large gamme de dispositifs de récupération d'énergie des vibrations mécaniques a été développée. Une configuration commune consiste en un système de masse-ressort avec un matériau piézoélectrique en parallèle avec le ressort pour convertir une partie de l'énergie mécanique pendant les oscillations en énergie électrique. Jusqu'à présent, le matériau le plus utilisé pour la récupération d'énergie piézoélectrique est le titano-zirconate de plomb (PbZr1-xTixO3) (PZT). Le PZT est le matériau de référence pour les applications microsystème électromécanique-MEMS (MechanoElectroMechanicalSystems) dans le domaine de la récupération d'énergie. Les matériaux piézoélectriques à base de plomb tels que le PZT et niobate-titanate de plomb-magnésium (PMN-PT) offrent des facteurs de couplage piézoélectriques supérieurs à ceux d'autres matériaux. Cependant, malgré ses excellentes propriétés électriques (diélectriques, ferroélectriques et piézoélectriques), le PZT et d'autres matériaux à base de plomb devraient bientôt être remplacés par des composés sans plomb, à cause des problèmes environnementaux. Notre travail vise à développer des matériaux sans plomb de haute performance pour la récupération d'énergie par vibration mécanique. Nous nous sommes intéressés à la fabrication et la caractérisation des dispositifs MEMS pour la récupération d'énergie en utilisant les matériaux piézoélectriques sans plomb tels que le nitrure d'aluminium (AIN), le titanate de baryum BaTiO3 (BTO) et la ferrite de bismuth BiFeO3 (BFO). Les matériaux piézoélectriques PZT (utilisé comme référence à cause ses coefficients piézoélectriques élevés), BTO, BFO et AIN ont été déposés en utilisant des méthodes de dépôt telles que la pulvérisation cathodique et le dépôt sol-gel, conduisant à des films minces à grande échelle, homogènes et de haute densité, avec une épaisseur contrôlée avec précision. Le dépôt de films de 300 nm d'épaisseur par pulvérisation cathodique ou par Sol-Gel a été réalisé sur du substrat de SrTiO3 (STO) recouvert d'une électrode inférieure de SrRuO3 (SRO), qui est le substrat de référence pour les oxydes fonctionnels (PZT, BTO et BFO), et sur un substrat de silicium recouvert de platine, qui est le modèle industriel classique. Quels que soient les matériaux piézoélectriques, nous avons obtenu des films épitaxiés sur substrat de STO et texturés sur substrat de silicium. Des mesures structurales, électriques et piézoélectriques sur les films de BTO, AIN et PZT montrent qu'ils ont de bonnes propriétés physiques en accord avec la littérature.
TH_T2625_bwague.pdf (6.84 Mo) Télécharger le fichier
tel-01893847 , version 1 (11-10-2018)
  • HAL Id : tel-01893847 , version 1
Baba Wague. Matériaux sans plomb micro structurés pour la récupération d'énergie. Autre. Université de Lyon, 2018. Français. ⟨NNT : 2018LYSEC003⟩. ⟨tel-01893847⟩
377 Consultations
293 Téléchargements
