Fusion multimodale pour la reconnaissance d'espèces d'arbres - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2018
Multimodal fusion for leaf species recognition
Information fusion systems allow the combination of data issued from different sources of information while considering their quality. Combining data from heterogeneous sources makes it possible to take advantage of the complementarity of the data and thus potentially have higher performances than those obtained when using a single source of information.The use of these systems is interesting in the context of tree species recognition through the fusion of information issued from two modalities : leaves and barks. A single modality may represent different sources of information, each describing one of its most relevant characteristics. This makes it possible to reproduce the strategy adopted by botanists who base themselves on these same criteria. The adoption of this strategy is part of the enhancement of the educational aspect. In this context, a merger system is conceivable in order to combine the data issued from one modality as well as the data issued from different modalities. In the context of tree species recognition, we treat a real problem since the photos of leaves and bark are taken in the natural environment. The processing of this type of data is complicated because of their specificities due firstly to the nature of the objects to be recognized (age, inter-species similarity and intra-species variability) and secondly to the environment.Errors can be accumulated during the pre-fusion process. The merit of the fusion is to take into account all the imperfections that can taint the available data and try to model them well. The fusion is more effective if the data is well modeled. The theory of belief functions represents one of the best theoretical frameworks able to manage and represent uncertainty, inaccuracy, conflict, etc. This theory is important because of its wealth of tools to manage the various sources of imperfections as well as the specificities of the available data. In the framework of this theory, it is possible to model the data through the construction of mass functions. It is also possible to manage the computational complexity thanks to the approximations allowing to reduce the number of focal elements. Conflict being one of the most present sources of imperfections, can be dealt through the selection of the best combination rule.By merging sources of information with different degrees of reliability, it is possible that the least reliable source affects the data issued from the most reliable one. One of the solutions for this problem is to try to improve the performances of the least reliable source. Thus, by merging with other sources, it will provide useful information and will in turn contribute in improving the performance of the fusion system.The performance improvement of an information source can be effected through the correction of mass functions. In this context, the correction can be made based on measures of the relevance or sincerity of the studied source. The confusion matrices present a data source from which meta-knowledge characterizing the state of a source can be extracted. In this manuscript, the proposed fusion system is a hierarchical fusion system set up within the framework of belief function theory. It allows to merge data from leaves and barks and provides the user with a list of the most likely species while respecting the educational purpose of the application. The computational complexity of this fusion system is quite small allowing, in the long term, to implement the application on a Smart-phone
Les systèmes de fusion d’informations permettent de combiner des données issues de différentes sources d’informations tout en tenant compte de leur qualité. La combinaison de données issues de sources hétérogènes permet de profiter de la complémentarité des données et donc d’avoir potentiellement des performances plus élevées que celles obtenues en utilisant une seule source d’informations. L’utilisation de ces systèmes s’avère intéressante dans le cadre de la reconnaissance d’espèces d’arbres à travers la fusion d’informations issues de deux modalités : les feuilles et les écorces.Une seule modalité représente éventuellement différentes sources d’informations décrivant chacune une des caractéristiques les plus pertinentes. Ceci permet de reproduire la stratégie adoptée par les botanistes qui se basent sur ces même critères lors de la reconnaissance. L’adoption de cette stratégie entre dans la mise en valeur de l’aspect éducatif. Dans ce cadre, un système de fusion est envisageable afin de combiner les données issues d’une même modalité ainsi que les différentes modalités disponibles. Dans le contexte de la reconnaissance d’espèces d’arbres, il s’agit d’un problème réel où les photos des feuilles et des écorces sont prises en milieu naturel. Le traitement de ce type de données est compliqué vue leurs spécificités dues d’une part à la nature des objets à reconnaître (âge, similarité inter-espèces et variabilité intra-espèce) et d’autre part à l’environnement.Des erreurs peuvent s’accumuler tout au long du processus précédant la fusion. L’intérêt de la fusion est de prendre en compte toutes les imperfections pouvant entacher les données disponibles et essayer de bien les modéliser. La fusion est d’autant plus efficace que les données sont bien modélisées. La théorie des fonctions de croyance représente l’un des cadres théoriques les plus aptes à gérer et représenter l’incertitude, l’imprécision, le conflit, etc. Cette théorie tire son importance de sa richesse en termes d’outils permettant de gérer les différentes sources d’imperfections ainsi que les spécificités des données disponibles. Dans le cadre de cette théorie, il est possible de modéliser les données à travers la construction de fonctions de masse. Il est également possible de gérer la complexité calculatoire grâce aux approximations permettant de réduire le nombre d’éléments focaux. Le conflit étant l’une des sources d’imperfections les plus présentes, peut être traité à travers la sélection de la règle de combinaison la mieux adaptée.En fusionnant des sources d’informations ayant des degrés de fiabilité différents, il est possible que la source la moins fiable affecte les données issues de la source la plus fiable. Une des solutions pour ce problème est de chercher à améliorer les performances de la source la moins fiable. Ainsi, en la fusionnant avec d’autres sources, elle apportera des informations utiles et contribuera à son tour à l’amélioration des performances du système de fusion. L’amélioration des performances d’une source d’informations peut s’effectuer à travers la correction des fonctions de masse. Dans ce cadre, la correction peut se faire en se basant sur des mesures de la pertinence ou de la sincérité de la source étudiée. Les matrices de confusion présentent une source de données à partir desquelles des méta-connaissances caractérisant l’état d’une source peuvent être extraites.Dans ce manuscrit, le système de fusion proposé est un système de fusion hiérarchique mis en place dans le cadre de la théorie des fonctions de croyance. Il permet de fusionner les données issues des feuilles et des écorces et propose à l’utilisateur une liste des espèces les plus probables tout en respectant l’objectif éducatif de l’application. La complexité calculatoire de ce système de fusion est assez réduite permettant, à long termes, d’implémenter l’application sur un Smart-phone
BEN_AMEUR_2018_archivage.pdf (16.48 Mo) Télécharger le fichier
tel-01921590 , version 1 (13-11-2018)
  • HAL Id : tel-01921590 , version 1
Rihab Ben Ameur. Fusion multimodale pour la reconnaissance d'espèces d'arbres. Traitement du signal et de l'image [eess.SP]. Université Grenoble Alpes, 2018. Français. ⟨NNT : 2018GREAA005⟩. ⟨tel-01921590⟩
327 Consultations
90 Téléchargements
