Asynchronous optimization for machine learning - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2018
Optimisation asynchrone pour l'apprentissage statistique
The impressive breakthroughs of the last two decades in the field of machine learning can be in large part attributed to the explosion of computing power and available data. These two limiting factors have been replaced by a new bottleneck: algorithms. The focus of this thesis is thus on introducing novel methods that can take advantage of high data quantity and computing power. We present two independent contributions. First, we develop and analyze novel fast optimization algorithms which take advantage of the advances in parallel computing architecture and can handle vast amounts of data. We introduce a new framework of analysis for asynchronous parallel incremental algorithms, which enable correct and simple proofs. We then demonstrate its usefulness by performing the convergence analysis for several methods, including two novel algorithms. Asaga is a sparse asynchronous parallel variant of the variance-reduced algorithm Saga which enjoys fast linear convergence rates on smooth and strongly convex objectives. We prove that it can be linearly faster than its sequential counterpart, even without sparsity assumptions. ProxAsaga is an extension of Asaga to the more general setting where the regularizer can be non-smooth. We prove that it can also achieve a linear speedup. We provide extensive experiments comparing our new algorithms to the current state-of-art. Second, we introduce new methods for complex structured prediction tasks. We focus on recurrent neural networks (RNNs), whose traditional training algorithm for RNNs – based on maximum likelihood estimation (MLE) – suffers from several issues. The associated surrogate training loss notably ignores the information contained in structured losses and introduces discrepancies between train and test times that may hurt performance. To alleviate these problems, we propose SeaRNN, a novel training algorithm for RNNs inspired by the “learning to search” approach to structured prediction. SeaRNN leverages test-alike search space exploration to introduce global-local losses that are closer to the test error than the MLE objective. We demonstrate improved performance over MLE on three challenging tasks, and provide several subsampling strategies to enable SeaRNN to scale to large-scale tasks, such as machine translation. Finally, after contrasting the behavior of SeaRNN models to MLE models, we conduct an in-depth comparison of our new approach to the related work.
Les explosions combinées de la puissance computationnelle et de la quantité de données disponibles ont fait des algorithmes les nouveaux facteurs limitants en machine learning. L’objectif de cette thèse est donc d’introduire de nouvelles méthodes capables de tirer profit de quantités de données et de ressources computationnelles importantes. Nous présentons deux contributions indépendantes. Premièrement, nous développons des algorithmes d’optimisation rapides, adaptés aux avancées en architecture de calcul parallèle pour traiter des quantités massives de données. Nous introduisons un cadre d’analyse pour les algorithmes parallèles asynchrones, qui nous permet de faire des preuves correctes et simples. Nous démontrons son utilité en analysant les propriétés de convergence et d’accélération de deux nouveaux algorithmes. Asaga est une variante parallèle asynchrone et parcimonieuse de Saga, un algorithme à variance réduite qui a un taux de convergence linéaire rapide dans le cas d’un objectif lisse et fortement convexe. Dans les conditions adéquates, Asaga est linéairement plus rapide que Saga, même en l’absence de parcimonie. ProxAsaga est une extension d’Asaga au cas plus général où le terme de régularisation n’est pas lisse. ProxAsaga obtient aussi une accélération linéaire. Nous avons réalisé des expériences approfondies pour comparer nos algorithms à l’état de l’art. Deuxièmement, nous présentons de nouvelles méthodes adaptées à la prédiction structurée. Nous nous concentrons sur les réseaux de neurones récurrents (RNNs), dont l’algorithme d’entraînement traditionnel – basé sur le principe du maximum de vraisemblance (MLE) – présente plusieurs limitations. La fonction de coût associée ignore l’information contenue dans les métriques structurées ; de plus, elle entraîne des divergences entre l’entraînement et la prédiction. Nous proposons donc SeaRNN, un nouvel algorithme d’entraînement des RNNs inspiré de l’approche dite “learning to search”. SeaRNN repose sur une exploration de l’espace d’états pour définir des fonctions de coût globales-locales, plus proches de la métrique d’évaluation que l’objectif MLE. Les modèles entraînés avec SeaRNN ont de meilleures performances que ceux appris via MLE pour trois tâches difficiles, dont la traduction automatique. Enfin, nous étudions le comportement de ces modèles et effectuons une comparaison détaillée de notre nouvelle approche aux travaux de recherche connexes.
Leblond-2018-These.pdf (4.85 Mo) Télécharger le fichier
tel-01950576 , version 1 (10-12-2018)
tel-01950576 , version 2 (29-01-2020)
  • HAL Id : tel-01950576 , version 2
Rémi Leblond. Asynchronous optimization for machine learning. Machine Learning [cs.LG]. Université Paris sciences et lettres, 2018. English. ⟨NNT : 2018PSLEE057⟩. ⟨tel-01950576v2⟩
510 Consultations
767 Téléchargements
