Rôle des microARNs cellulaires et vésiculaires dans la régulation transcriptomique du système nerveux - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2017
Role of cellular and vesicular microRNAs in the transcriptomic regulation of the nervous system
This work consists in stuying the expression, the role and the transport of microRNAs (miRNAs) in the central nervous system (CNS). microRNAs (miRNAs) are small endogenous non coding RNAs, exerting a negative regulation on gene expression.They inhibit protein translation by hybridization on the 3’ untranslated region of mRNA.First, we have revealed the specific role of miR-92a in the control of the expressionof GluA1, in an homeostatic plasticity paradigm in which the synaptic plasticity is inhibited.Second, by using RNA-Seq technology, we showed that miRNAs are differentially expressed in the different structures of the CNS. Moreover, we have discovered new species of miRNAs. Finally, our results suggest that the miRNA expression (of known and new miRNAs) participate in the singular transcriptomique signature of each structure.Third, we have shown that miRNAs are transported into EVs, and can be exchanged between the cells of the CNS. The miRNA content of EVs varies depending on neuronal activity. Target prediction of these miRNAs includes genes involved in the regulation of neuronal plasticity. Together, our results suggest that the exchange of miRNAs through EVs is a new mechanism involved in the modulation of neuronal plasticity. Finally, we propose a new tool for purifiying EVs depending on their cellular origin.To conclude, this study allows a better understanding of the role of miRNAs in the regulation of the physiology of the CNS.
Ce travail consiste à étudier l’expression, le rôle et l’échange des microARNs (miARNs), dans le système nerveux (SN). Les microARNs (miARNs) sont des petits ARNs endogènes non-codants qui exercent une régulation négative sur l’expression desgènes, en s’hybridant sur la région 3’ non-codante des ARNm cibles.Dans un premier, nous avons dévoilé le rôle spécifique du miR-92a, dans lecontrôle de l’expression de la sous-unité GluA1 des récepteurs AMPA, dans un paradigme de plasticité synaptique homéostatique, dans lequel la plasticité synaptique est inhibée.Nous avons ensuite montré, par RNA-Seq que les miARNs sont différentiellement exprimés entre les structures du SN. Cette technologie nous a aussi permis de révéler la présence de nouvelles espèces de miARNs. De plus les résultats suggèrent que l’expression des miARNs (connus et nouveaux) participe à la signature transcriptomique singulière de chacune des structures.Dans un troisième temps, notre travail montre que les miARNs peuvent être échangés entre les cellules du système nerveux via les vésicules extracellulaires (EVs). Le contenu des EVs en miARNs varie en fonction de l’activité neuronale, et ces derniers ont pour cibles prédictives des protéines impliquées dans la régulation de la plasticité neuronale. Nos résultats suggèrent donc que l’échange de miARNs via les EVs est un nouveau mécanisme de modulation de la plasticité neuronale.Enfin, nous proposons un nouvel outil de purification des EVs, qui à l’avenir permettrait de purifier les EVs du SNC selon leur origine cellulaire.Pour conclure, ce travail apporte une meilleure compréhension du rôle des miARNs dans la régulation de la physiologie du SNC.
SOULA_ANAIS_2017.pdf (140.79 Mo) Télécharger le fichier
tel-01952195 , version 1 (12-12-2018)
  • HAL Id : tel-01952195 , version 1
Anaïs Soula. Rôle des microARNs cellulaires et vésiculaires dans la régulation transcriptomique du système nerveux. Neurosciences [q-bio.NC]. Université de Bordeaux, 2017. Français. ⟨NNT : 2017BORD0794⟩. ⟨tel-01952195⟩
150 Consultations
44 Téléchargements
